Hello im new need a few bits of advise.
veedub89 Feb 28, 2013
  1. veedub89
    veedub89 New Member
    14
    right i could do with a few bits of help please guys, i have an a4 quattro sport 1.8t estate.
    need help with the following
    • rear washer dosnt work, it pumps water into passenger foot well. is there a join near there or could it be a split?
    • the boot you have to slam quite hard. the lip of boot lid rubs on the bumper. any ideas? could i adjust the hinges?
    • in the engine bay, i have noticed 2 fans on the rad. 1 constant and 1 electric, the engine dosnt seen to get very hot, is this because of the constant fan?or does the system need bleeding for air?
    • and any quick or easy fixs for the computer display in the clocks.? the top section works ok which shows abs fuel warnings ect. but the bottom section has lots of line through it, does it display mpg?
    • oh and abs light is on. any ideas.
    cheers in advance
  2. gavlangley88
    gavlangley88 New Member
    If your ABS light is on it is most likely an ABS sensor that has gone, My MK 4 golf went through quite a few of these, The best way to check is to run VAGCOM on your car, I was able to clear the errors to get it through its MOT but ended up changing the sensor in the end.
    Again, with the passanger footwell problem, i ended up changing my door seal as thats what was causing my leak but audi may be different, i am new to audi but im sure someone on here will be able to help you.
    I hope this helps for now
  3. Sulli79
    Sulli79 Active Member
    541
    37
    What temperature do you get on the gauge?
  4. veedub89
    veedub89 New Member
    14
    i am pretty sure its not a door seal as it only comes in if i use the rear washer. whats a vagcom? diagnostic machine?
    cheers
  5. veedub89
    veedub89 New Member
    14
    about 1/4, and the heating is warmish.
  6. gavsman
    gavsman Member
    379
    Pic looks like you have a B5 Avant, you might get some more advise over in the B5 section ( ScottB5 would be the man to ask!)
    A4/S4 forum(B5 Chassis)
  7. gavlangley88
  8. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    27,704
    10,781
    Thread moved to correct section. :) x
  9. Sulli79
    541
    37
    Temp should sit about 90 degrees, so change your thermostat for a new one, look on the vagcom section and see if there is any body local to you who may be able to scan the car and locate which abs sensor is at fault, pretty sure the estate does feed it's washer that side, but also check your scuttle drain are clear too
  10. Sandra
    27,704
    10,781
    VCDS (formerly VAG-COM) forum
    click on the blue balloons in your area, a box opens up with the members details, click the link and send them a pm. :) x
  11. gavsman
    gavsman Member
    379
  12. veedub89
    veedub89 New Member
    14
    cheers for you help guys, does anyone have any idea about the boot lid?
    oh and the badge on the grill and boot says s2, any reasons?
  13. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    3,988
    756
    Someone has been a prat and stuck them on there!
  14. veedub89
    veedub89 New Member
    14
    wot evan is an s2?
  15. B5NUT
    3,988
    756
    This is an S2 Avant
  16. B5NUT
    3,988
    756
    And the S2 Coupe, I love this car!
