HEEELLLLPPPPPPP!!!!!!! QUICK!!!!!!
Ads Jun 25, 2010
  1. Ads
    Ads License to drive
    8,230
    607
    Just got back from driving to the shop and my electric windows have died, so has the central locking.
    Was working one minute and the next nothing.
    My key fob doesn't work either.
    Here is my vagcom scan:
    Address 09: Cent. Elect.
    Control Module Part Number: 8P0 907 279 F
    Component and/or Version: Bordnetz-SG H43 1201
    Software Coding: 018C4F27A014100000000000000000000008FE175C0100
    Work Shop Code: WSC 06314
    Additional Info: 8P2955119B Wischer AU350 H01 0130
    1 Fault Found:
    01330 - Central Control Module for Central Convenience (J393)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 9
    Reset counter: 209
    Mileage: 75924 km
    Time Indication: 0
    Date: 2010.06.25
    Time: 18:32:00
    Freeze Frame:
    OFF
    Voltage: 12.60 V
    OFF
    ON
    OFF
    OFF
    OFF
    Can't access Central convenience module at all.
    Please HELP!!!
    Also, how do I close my windows manually???
  2. GAudiTech
    GAudiTech Member
    What model is it?. Try disconecting the battery for 10mins and try again
  3. GAudiTech
    GAudiTech Member
    sorry spotted your pic..A3 i guess!
  4. Ads
    8,230
    607
    Sorry, yeah, it's an A3 (8P) 2006 2.0TFSI
  5. GAudiTech
    GAudiTech Member
    J393 in in the boot at the right hand side behind the cover. Check fuse 13 i think (10amp) at side of dash and fuse 43 (20amp)
  6. Ads
    8,230
    607
    Fuse 13 looks fine, 43 doesn't has a fuse in it.
    Gonna have a look in the boot behind the cover.
    You know how to close the window manually. (front passenger side).
    This is a race against time!!!!!!!!!!!!!!!!!
  7. Ads
    8,230
    607
    Opened to the boot (couldn't find a cover!!), got back in car, started it up to move it a bit, windows started working again!
    Cleared fault codes and rescanned, no faults codes coming back..... yet!
    What's going on??? I feel like this isn't over.
  8. GAudiTech
    GAudiTech Member
    sorry just doubled checked, fuse 43 is only if battery is in boot (v6). The cover is the panel at the right (screw and clips holding it on) but no easy access panel. Might be a loose conection on the control unit
  9. Ads
    8,230
    607
    I'll have a look in the morning.
    Found this fault also:
    Address 46: Central Conv.
    Control Module Part Number: 8P0 959 433 C
    Component and/or Version: KSG H04 0050
    Software Coding: 198000186D288505489AC63300
    Work Shop Code: WSC 00060
    Additional Info: 1K0951605C LIN BACKUP HORN H03 1301 1K0907719C Neigungssensor 005 0003
    Additional Info: 8P0951177 Innenraumueberw.H04 0020
    1 Fault Found:
    00352 - Terminal 30A
    011 - Open Circuit
  10. GAudiTech
    GAudiTech Member
    terminal 30 is battery live. this may of come on cus you pulled the fuse 13 out.
