Heavy Steering and Battary warning light on ___ Help
rockfanatic Jun 14, 2007
  1. rockfanatic
    rockfanatic New Member
    Hi all,
    I have a serious problem i think. I have an A6 1999 Limousine 2.5 TDI V6 , Suddenly my Battery warning light has come on and the power steering is really heavy. What is the problem
    please help
  2. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    Sounds like the auxilliary belt has come adrift because it powers the alternator (the battery light) and the power steering pump (the heavy steering)
  3. rockfanatic
    Thanks, Do you have any idea how expensive it would be to repair, and iwould it be safe to drive to a dealer???
  4. simonwjones
    simonwjones Member
    365
    happened on my old 2.8q.
    Its possible to drive but very hard work. The only thing is the battery wont be charging, so possibly, it could drain the battery low enough to not be able to power the ecu etc and you will stop.
    parts wise its very cheap, its just labour to get to it. should only be a couple of hours work though
    Simon
  5. rockfanatic
    I will drive to Garage in morning. its only 10Km away
  6. android
    android New Member
    10
    Sounds like definaltely the alternator (or belt)
    Mine went in December whilst abroad and cost around 700 Euro to fix
    Alternator was 400 & labour 300 (At an Audi dealership)
    I have the 2.7T so yours may be less expensive
    I will not be driving the car too far though as you dont want the battery to drain and risk other electrical issues
  7. PlebbyChris
    PlebbyChris Complete Pleb
    89
    You could always have a go yourself if you have a basic engineering knowledge. The drive belt isn't as tricky as a cam belt.
    If it's only slipping on the pulleys then you might even get away with just retensioning it, but it depends on how damaged the belt is from the slipping.
  8. rockfanatic
    I will tell you all what the dealership said and quoted, as soon as I know..
  9. rockfanatic
    okay car is back, Bel;t snapped and then managed to snap the Idler, This then caused more damage.
    in all though the cost with labour came to €1550 Euro
    Thanks to all who replied and tried to help me
  10. Caesium
    4,879
    That seems rather expensive!
  11. simonwjones
    simonwjones Member
    365
    I think you've been taken for a ride there.
    If all they have done is changed the auxiliary belt it should only be a couple of hours work.
    I know on my V6, its front bumper off and pulll forward the radiator etc, but I now how long its takes as I helped my mate change the water pump a couple of weeks ago.
    Even a stealer rates it wshould have been no more than £3-400
    Simon
