Heavy power steering
epox Oct 15, 2012
  1. epox
    epox Active Member
    772
    74
    Hi Guys,
    new to the forun.
    i have just got a 2003 S3 bam, the power steerings seems heavy when parking.
    is this normal? if not any ideas.
    thanks mark
  2. <tuffty/>
    21,012
    3,772
    Steering is a little heavier on S3's than other VAGs as it has a quick rack... do you get a groaning noise when you are on full lock? if so check the fluid levels... common point for leaks is the pipework that runs in front of the sump/gearbox from the power steering pump...
  3. epox
    epox Active Member
    772
    74
    Hi thanks for the quick reply. no noise at all when putting it on full lock. fliud seems ok.
    hight just have to get used to it
    thanks mark
  4. MURRAYS444
    MURRAYS444 Member
    790
    Check your tyre pressure they could be low!
