Heatshield FAIL - Look inside, DONT DO THIS
badger5 Aug 28, 2011
  1. badger5
    9,603
    2,061
    Okies...
    A car here which has some owner enthusiast diy work done to it, in prep for a bigger turbo being fitted/mapped here etc... Unfortunately, a poor choice of heat shielding material against the bulkhead, and OE heatshield removed, would have left the car as a fire hazard if it had been used and left there.
    Do not use Household sticky back foamed silver foil fronted heat reflective material for an automotive heatshield.. this material is what you would stick behind household radiators to reflect their heat off the walls.
    anyhows.. see below what happens when it gets hot vs some Actual Heatsheild materials like should be used in the engine bay..
    What not to use below
    Aluminised Fibreglass Cloth-aluminised burns off but fabric remains intact
    3 layer embossed aluminium/ceramic composite
    Use the Appropriate materials for your builds guys..
  2. Speedy Steve
    Speedy Steve Active Member
    1,258
    Lol next they'll be using tumble dryer ducting for air feeds
  3. S3 Sly
    S3 Sly Member
    122
    Is it just me that can see the face of a dog in the first pic?
  4. rhubarb4
    rhubarb4 Certified Audi nutter Gold Supporter Team Silver Audi S3 quattro
    1,754
    188
    no its clearly jesus lol
  5. MUSH
    MUSH MUSH Developments Ltd.
    713
    12
    Interesting!
    That ali/ceramic shielding is impressive!
    Im using triple layers of ali heatshielding from a specialised insulation company. The type of stuff they wrap turbines/jet engines and AMG turbos with.
    Ive got some sheets of the same design but in stainless and even titanium that the engineers reckon is even better aswell. Havnt tried that though.
  6. badger5
    9,603
    2,061
    epic fail for using foam backed household insulation tho.
    it might be shiney surface but it could'nt be much worse for automotive heatshielding - scarey really.
    he removed the oe stuff to install this instead - eak/woops
  7. Lee172
    Lee172 GT3071
    430
  8. <tuffty/>
    21,899
    4,206
    Humm... although it is adverstised as exhaust heatshield it should also be noted that turbo applications are a little different to what this stuff suggests its for...
    Exhausts on a motorcycle are unlikely to see the sort of heat that a turbo application will... when the amount of heat generated is enough to make metal glow red or in some case white hot then you know something thats 'foam backed' isn't really gonna cut the mustard...
    I have used these people before and the products are good..
    Exhaust Wrap Shop
    ...even if thier website is ****e!... lol
    Advice is to do a little research and of course ask on the forum if you are still unsure...
  9. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    i LOL'd
    I'm not gonna lie though, i thought it was a face aswell!
  10. sportstractor
    sportstractor Chugger
    2,709
    Although direct flame is a slight exaggeration on the heat generated, as propane burns at nearly 2000 degrees, that is mad. That radiator foil can't even hack the temperatures behind a radiator, let alone a turbo! Madness
  11. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    i know someone who actually did that. They spray it black first aswell
  12. badger5
    9,603
    2,061
    extreme test - yes. but the proper materials copes admirably.. and when you run a k04 hard it is radiating some 900'C temps for quite some duration..
  13. Yohan87
    Yohan87 Guest
    Bill,
    Where can I get my hands on that 3 layer embossed aluminium/ceramic composite material?
  14. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    +1 on that?
  15. badger5
    9,603
    2,061
  16. Yohan87
    Yohan87 Guest
  17. badger5
    9,603
    2,061
    yep
