Heating
Biddy Apr 3, 2013
  1. Biddy
    Biddy Member
    75
    Hi all got a4 18t 2002 heater blows cool air little bit of heat sometimes top hose is hot bottom hose is cold both heater matrix hoses luke warm flushed heater matrix and its clear any ideas pls
  2. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    Does the car get up to temperature ok?
  3. Biddy
    Biddy Member
    75
    Yes mate sits at 90 all the time doesnt drop or increase
  4. madmike01uk
    madmike01uk Member
    430
    21
    is your coolant up to the max mark? If it's low you won't get any hot air into the cabin.
  5. Biddy
    Biddy Member
    75
    Hi yes coolant is up to max mark
  6. hades-
    9,481
    646
    air in the system ?
    its a ****er to get out
  7. Biddy
    Biddy Member
    75
    Bleed it at top heater hose and from metal pipe that runs over top off engine no air coming out of either just water
  8. stu_m
    1,441
    If your getting up to temp ok then it can only be air or a blockage somewhere
    Did it just stop working or is it after a coolant change? If it just stopped I would go with the blockage
  9. Biddy
    Biddy Member
    75
    Not worked well ever since iv had it i have flushed system new rad every thing seems to flow ok only thing is bottom hose stays cold and top hose hot and matrix hoses cool flushed matrix and flowed ok running out of solutions at least we are getting some sunshine keeps me warm lol
  10. Mike B
    Mike B Well-Known Member
    1,107
    40
    ARE the control flaps OK?
  11. Biddy
    Biddy Member
    75
    To be honest dont know how do i check pls
  12. stu_m
    1,441
    When you say top and bottom hose do you mean at the rad at the front if so there's nothing wrong with that it means the rad is doing its job
    If one of the hoses out the heater matrix is cold your problem lies within the heater matrix
  13. Biddy
    Biddy Member
    75
    Hi yes top hose out of rad hot bottom hose which i think goes to thermostat is cold both hoses from matrix luke warm
  14. stu_m
    1,441
    dont worry about the ones at the rad the bottom one is the cold inlet to the engine it should be cold
    someone has mentioned before about something you put in the coolant that flushed the system out and is supposed to work great....I dont know what it is called though!
    and also as mentioned check the flaps to make sure they are operating as they should
  15. Biddy
    Biddy Member
    75
    Ok cheers how do i check flaps pls
  16. stu_m
    1,441
    you would have to remove the glove box and there is also one on the drivers side
    I cant remember off the top of my head which ones are which
    a scan should show a problem with them plus you can check the operation with vcds
  17. Biddy
    Biddy Member
    75
    Ok mate thanks for all the replys
