Heating smells of puke!!
DJ_Troopa Apr 15, 2010
  1. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    Ello people
    As above... my heating in the car smells of puke!! It's been smelling bit funky the past couple months but 2 days ago this big strong smell of it came out! Can't even put my heating on as it smells so bad!!
    What is it :(
    Jay
  2. MintyS3
    MintyS3 Works 60% the time, Everytime.
    1,580
    Aircon or just normal blowers?
  3. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    I haven't tried the air con yet. But when i start the car from cold with the blowers on and the cold comes out you can't smell anything. When the car warms up and you can feel the heat coming it starts smelling!
    Gimme 2 mins i'll check the AC
    :icon_thumright:
  4. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    Okay, so just got out of the car after letting it warm up and cooking my ass off. I can't smell it now! I haven't used my heating for 2 days because of this smell and now its just gone? Last night i drove home late night and it stunk then so i don't know where this mysterious smell has gone?
    If this happens again does anyone know what it could be?
  5. finesse
    finesse Active Member
    2,805
    Last pollen filter change?
  6. jojo
    jojo Looking for Boost! Staff Member Moderator Team Daytona quattro Audi S3 Audi A6 Audi Avant Owner Group
    28,825
    3,479
    As above mate, change pollen filter, think they are a tenna from your local motor factors.
  7. finesse
    2,805
    £4 from GFS or Euro
  8. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    Was going to be my suggestion as well.
  9. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    Thanks people, i thought the same thing too when it first started smelling lol.
    Well after the above post where i couldn't smell anything, the car had been sat on my drive all night and wasn't moved anywhere. I've just come to work after a 20min drive, turned the heating on to check it out and it stinks again!
    So it only seems to smell after a drive? Do you stil think its the pollen filter?
  10. JD09
    3,096
    46
    Would be the first thing I change for such a low maintenance/cost part fella, yeah.
  11. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,117
    1,956
    cat puked in your inlet by the wipers ?
  12. jojo
    28,825
    3,479
    The actual smell is coming from the extracted water when your aircon is working in these warmer climates. It's best to start with tthe pollen filter first, as the aircon flow goes through this first, so if it's contaminated, you get this sick smell.
  13. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    its actually your air con system! mould/bacteria grows on the condeser, you can buy a disinfectant bomb from halfords that should get rid..designed for it
    try putting the air con on in winter for a few hours when driving, also helps the seals :icon_thumright:.
  14. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    I heard it adds 25bhp. I thought my car felt a bit quicker! :racer:
  15. JD09
    3,096
    46
    ^^^ That's a good suggestion. But be careful, people I know have been bent over before for these cleaner bombs. £70 according to one poor sod!
  16. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    Is it actually called a disinfectant bomb? lol. How much and how do i deploy the bomb!?
  17. s3dave
    10,110
    736
    yes, you turn on the air con full blast, and make sure all windows are up then break the aerosol seal then get out quickly it uses all the can and you leave the engine running/door closed for about 20 mins..
  18. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    LOL! Sounds fun! How does it work then and get rid of the heater problem?
  19. Effect
    Effect Member
    469
    It will be called air con cleaner or some thing similar.
    It smells strongly of lemon (or at least the one i used did)
    I had to set the aircon to LOW (making sure air con is on of course) also make sure it is on recirculate, you then put the passenger seat as far forward as poss and also tilt it forward, set the "bomb" on the rear passenger footwell, crack it open and it is basicly just a pressurised air container with anti bacterial guff in it which is then recirculated around the air-con/heater system to kill all the smelly bacteria in there.
  20. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    Cheers matey. Will have a look in Halfords tomorrow! :)
  21. AndyMac
    9,832
    45
    And to avoid this problem you should always keep the climate control on, it is designed to be used all year round not just when it's hot. If you only use occasionally then the bacteria starts to build up as well as the seals drying out and causing leaks & premature failure of the system
  22. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    I'lll second the above. I run mine all the time and it doesnt smell like puke :)
    Those things from Halfords are alright-ish, dont expect it to banish the smell 100% though.
  23. Nilz
    11,273
    845
    I use mine everyday, not had any probs either, for a cheap fix.....magic trees in your vents!! ;) LOL
  24. Westy
    Westy Well-Known Member
    17,440
    1,096
    My mate used one of those bombs and it made his car smell just like lemon and puke so he had to buy a strong smelling air freshner too. He also regassed his aircon and the smell hasn't come back since.
  25. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    lol where do i start!? Shall i get the bomb thing and see how that goes first?
  26. finesse
    2,805
    bomb it
  27. Welly
    Welly VX220 SC Driver :)
    10,696
    126
    That stuff is da bomb wot?
    Rinsin, propa bo!
  28. Welly
    10,696
    126
    Sorry, I came over all funny there for a minute. Normal service will be resumed momentarily.
    Wot?
  29. Nilz
    11,273
    845
    No dude, change your pollen filter 1st, its only a couple of quid, quick and easy, then just let the CC run for a while.
  30. Welly
    10,696
    126
    Agreed. Change pollen filter first.
    Then bomb it up.
  31. ALPINE
    3,093
    im unsure if the price of these bombs. but when ever i get my AC re-gassed it gets a decontaminate cycle. takes about 40 mins start to finish and is included in the price of a re-gas. (so im told my mate does mine for free!!)
    Smell gone and freshley gassed for the 6 days of summer we normally have. I would still change ya pollen filter as its pence.
  32. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    Just for reference and let people know...
    I went to Halfords and got the air con cleaner spray. Really easy to use and completely stunk the car of lemon zest lol. No more pukey heaters!! Woo!! :icon_thumright:
  33. finesse
    2,805
    Did you change the filter?
  34. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    Nope! I couldn't be arsed and seeing as i had to go Halfords that day i thought i'd see how the bomb would go first. It's all back to normal now so i'm not worrying about the pollen filter. It was only changed in September so it can't be that bad. If it happens again i'll check the filter but for now its smelling fine :)
    Thanks for the help people.
  35. Welly
    10,696
    126
    We told you that stuff was 'da bomb!
  36. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    a mate of mine put half a sandwich in my blower vent last summer when i went inside i had a disgusting smell for weeks until i found it the mofo!
    i got my revenge though when i loosened his exhaust in 3 places n it all fell off in bits on the way out his estate. The pranks stopped after that!
    anyway as mentioned id go with the pollen filter same thing in his A4 b5
  37. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    :respekt:
