Heaters stopped working any ideas?
djdougalno1 Jan 17, 2010
  1. djdougalno1
    djdougalno1 Member
    189
    ok this morning i noticed the heater making a funny noise like u could hear the fan inside as u turned it up it went away so i turned it off for a while then when i turned it on again nothing all the controls are working on the display but no air been blown through the vents any ideas what it could be. its pre facelift controls digital aswell
  2. rossbrownlee
    rossbrownlee Ross_S4
    719
    get it scanned mate there'll probably be a fault code up.
  3. HTC
    HTC Active Member
    3,428
    9
    Well if you were hearing strange noises then I'd imagine the motor has failed, but first check the fuse.
  4. Lemon S3
    Lemon S3 Alex
    1,390
    41
    It could be the wiring on the fan, you go over a bump n it'll come back on.
    What you want to do is remove the glove box which is held on by torx screws, theres 3 holding the top on as you open the glove box lid, remove the plastic cover on the side (like the fuse box cover) and there will be another 3 or 4 there, then there's 1 on the right side of the little shelf under the glove box.
    It will now come off and you will see the fan right in front of you, there is a big connector with 2 wires attached to it which is about 2 to 3 inches wide. Wriggle that about and your fan should come on, if not...then I don't know lol or the motor is on it's way out. If it does come on then you can either replace the plug or if you want a quick fix then wriggle it into a position where your fan works and tape it in place.
    Hope this helps!
  5. djdougalno1
    djdougalno1 Member
    189
    cheers guys will go an try now
  6. New2Audi
    New2Audi Member
    40
    Mine has done the same! :( Did you have any luck after your findings, and any remedy?
  7. Lemon S3
    Lemon S3 Alex
    1,390
    41
    I did make a thread on how to fix this but can't seem to find it.
  8. Lemon S3
    Lemon S3 Alex
    1,390
    41
  9. New2Audi
    New2Audi Member
    40
    Thats cool. So did you have to replace with a new fan ? How much?
  10. Lemon S3
    Lemon S3 Alex
    1,390
    41
    Nope didn't replace fan, just cut the plug and replaced with spade connectors. Been working perfect ever since.
