Heaters not working
mark.colledge Dec 9, 2011
  1. mark.colledge
    mark.colledge Member
    76
    Evening guys,
    i went to turn my heaters on and 1-3 dont work?
    however number 4 does.
    does anyone know a fix? i have checked fuses.
    thanks
  2. NHN
    29,422
    1,740
    Heaters, expand on this further please, as isnt really the best description.
  3. mark.colledge
    76
    sorry. the blowers?
    heat is there when its on 4 just it seems the switch that controls the other 4 aint working.
  4. NHN
    29,422
    1,740
    Ok so you have manual heating, not climate.
  5. mark.colledge
    76
    yeahh manual.
  6. Lewis583
    956
    91
    Just to be sure, do you mean the fan speed control? If so, the heater rheostat has the same symptoms when they fail (Only full speed works).
  7. mark.colledge
    76
    yes fan speed control.
  8. Ash187
    7,496
    744
    the resistor in the manual heating console has gone, just happened to a friend of mine in her ford focus. go to any good auto electrician and they should be able to sort it.
    your car is just using on and off instead of resistance assisted heating. so 0 = off and 4 = on. 1,2,3 is activated by the use of the resistor
  9. mark.colledge
    76
    i have ordered a heating console off ebay (apparently Working) and it still doesnt! ahhhhhh.
  10. mark.colledge
    76
    does anyone know where the resistors are located? under the glove box?
  11. Lewis583
    956
    91
  12. Khufu
    Khufu Well-Known Member
    5,704
    31
    was going to say it will be more likely attached to actual blower motor area. Had to do it on my mk2 golf & it was part of fan housing.
  13. mark.colledge
    76
    thanks.
    i have located the resistor and upon testing it it appears the thermal resistor had foooofffed up.
    i have ordered one so i hope that will sort it (fingers crossed).
    i dont think there is anything else it could be, could it?
