heater motor removal
Bigshugs
Ive got sticky bushes in my heater motor and tried to take the thing out to have a look and clean it out. I saw a lot of wee switchboxes and relays bolted on under the dash and stopped. Can they be removed safely without having to take the dash out ?
The blower motor???
Take the glovebox out and you'll get to it from there. Did mine a few months ago.
I took the glovebox out , but found some relays bolted on under the dash an they get in the way of removing the motor housing. Cant get the motor out without taking them or the dash off. Do i have to take the dash out or do the relays bolt off ?
The blower can be removed without removing any other electrical parts. You will need to remove a big metal bracket which is just a couple of 10mm bolts IIRC. That's the only part that is in the way. It's a 20min job tops.
9
9K
15
10K
