Heater Matrix Replacement
ScottD3 Feb 27, 2012
  1. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,163
    1,123
    Morning people.
    I'm planning on replacing my heater matrix in April and getting all parts ready.
    I'm ordering the heater matrix this week and some coolant.
    Apart from that can any one think of any thing else that needs replacing or recommend replacing?
  2. stoop44rio
    stoop44rio Member
    76
    Going by Haynes it looks like a dash out job!! Good luck if it is.
  3. a3tdi2001
    a3tdi2001 Member
    437
    Are you going for the genuine part from the dealer or TPS to minimise the hassle of doing it all over again further down the line? It's well worth disconnecting the oil cooler pipes and also the thermostat and giving the engine and radiator a right good flush through with a hose to remove any corrosion and also all the old coolant as I feel the matrix rusts from the inside out as the inhibitors in the coolant deplete with time.
  4. ScottD3
    15,163
    1,123
    Tuffty's
  5. ScottD3
    15,163
    1,123
    Genuine parts.
    I'm not going through the same hassle as Westy.
    I gave the system a drain and flush through when I replaced thermostat but I will do it again but not to the same extent.
  6. murran
    murran Well-Known Member
    1,545
    39
    its not too bad taking the dash out of one of these. nice job tbh.
  7. ScottD3
    15,163
    1,123
    Im looking forward to it really.
    Get to sort out some wiring and stop the bloody coolant smell.
    Just want to make sure I order all the bits.
    Matrix and G12.
    Next?
  8. ScottD3
    15,163
    1,123
    I got most of the bits to do the job this weekend.
    How do you bleed the system again?
  9. aragorn
    18,490
    855
    one of the heater hoses has a small hole in it, just pull it back to expose the hole, and fill with water till it comes out the hole.
  10. ScottD3
    15,163
    1,123
    In the bay or cab?
  11. aragorn
    18,490
    855
    Bay!
  12. ScottD3
    15,163
    1,123
    Done it.
    Took me a day and half to strip the car, relocated a relay, cleaned up some connections, rerouted some cables, wrapped my last bit of wood trim, replace the matrix and put it all back together again.
    Heres some pics.
    Before I've done any thing.
    Centre console nest of wires. This is what needed tiding up and the location of the relay that I moved where the other relays are.
    Half way.
    No more heater.
    One heater. This thing is huge.
    Just a little leak.
    The end of the day this is what my boot looked like.
    Next day I put it all back together, wrapped the wood trim in matt black. It now looks like this.
    With all the drained out and some spare time I went off and did some engine bay work.
    New EGR blank, Air box cover, New battery cover and new coolant bottle.
    Then a quick clean.
    Its job a I enjoyed, oddly but not one I really want to do again.
  13. CHEZ
    CHEZ moderately amusing Supporter
    4,172
    840
    well done scotty dog!
    you done good brother! nice to see it all fitted back together and works!
    the strip you wrapped looks the muts nuts mate! i like that a lot!
    now, tell the truth! how many nuts/bolts/screws/fixings were left over? and have you any rattles now?
    :beerchug:
  14. ScottD3
    15,163
    1,123
    No bolts left over.
    not driven it yet. lol
    I will tomorrow.
  15. olds_kool
    olds_kool Active Member VCDS Map User
    1,094
    15
    job well done !
    bay looks mint, i did wonder if you were going to fit that fancy cap to your old manky reservoir
    was blind switch from an a6? could you not fit fog, blank and cup holder from an a6 they'd all sit flush then
    where did you get the matt vinyl i need to cover my shift surround
  16. ScottD3
    15,163
    1,123
    Cheers mate. I got some other bay bits coming to finish it off.
    also want some plastic dip.
    The blind switch is from a B6. there is company that does a garage opener open for the B5, I might get that.
    I don't like the colour or size of the B6 button but if does the job for now.
    I bought the wrap off eBay.
    You can send me your centre and II'll do it for you or I can send you a section of wrap.
