Heater matrix - no hot air!!!
RickT Feb 16, 2007
  1. RickT
    RickT Member
    67
    Guys,
    I have got no hot air...... i have been away for a week, got into the car and all appeared fine.... as i have been out in -30'c conditions, i wacked the aircon on "LO" as i was red hot!! anyway... when changing it back to 18 upto 28 its cold... the air con turns off but only a tindy bit of heat... checked the simple stuff.. ie coolent...
    Going to get my laptop out and check VAGH-COM... however i think tjhe heater matrix has gone...
    Do any one know how to fit one on a A4 - B6??
    RicKT
  2. RickT
    RickT Member
    67
    or does anyone know how to test it via VAG-COM??
  3. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,797
    47
  4. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    5,356
    2,329
    You can't check the heater matrix with VAG-COM, If you are loosing coolant then it could be the matrix leaking you usually notice the smell in the car though assuming you have coolant in there as well as water.
  5. john777w
    john777w Active Member
    647
    85
    The heater Matrix can't go, it can leak, but rarely gets blocked, more likely that the hot/cold flap motor is not working. If you are loosing coolant, then you may have a matrix leak, is there anything wet inside the car?
