  1. hi recently got a 98 a4 18 se avant,this morning travell to work 4 miles heater wont blow warm air,took the longer run home tonite 8 miles and heater luke warm,temp wont rise above 70,stopped and checked hoses top hot bottom from the rad cold,and on restarting the engine the temp touched 90 breifley before dropping back down when i drove off,is it the thermostat:uhm:
  2. Blue_Thunder
    Blue_Thunder Well-Known Member
    1,774
    33
    Sounds very much like it.
  3. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,760
    660
    I would say the stat is stuck open.
  4. being a no brainer with engines,if the top of the engine is hot and the bottom cold and the stat is open why isnt the water at an even temp thruout the engine as it is being pumped round
  5. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,714
    162
    I'd say blocked radiator. Had this on a Matiz. Top a rad hot, bottom cold as that is where all the sludge was sat. Gave it a good flush with a hose pipe and all sorted.
    If stat was stuck open, then i'd agree all the pipes would be same temp but cool.
    could be heater matrix that is blocked too though. Check the hoses going into and out of the matrix from the engine bay bulkhead.
  6. B5NUT
    3,760
    660
    The rad is designed to cool the water going through it, also the heater matrix inside the car will also be cooling down the water. It should be hotter at the top than at the bottom, heat rises etc.
  7. S4_dan
    2,714
    162
    There wouldn't be a massive temp difference though as the car is stationary whilst feeling the pipes so the water wont be cooling that much compared to the top pipes?
  8. B5NUT
    3,760
    660
    If the rad was blocked the engine would over heat, same as if the stat was stuck closed, the only way to then cool the engine would be to put the heaters on full.
    Used to do that trick on an old Volvo, if the car was sat at idle I would start to over heat putting the internal heaters on full dropped the coolant temp back to 90.
  9. B5NUT
    3,760
    660
    The rad has to cool the water going through it otherwise the engine would over heat, you have the viscus fan sucking air through the rad and a backup electric fan if the temp climes.
  10. Mmm drove 20 miles tonite engine up to 90,heater still blowing cold,the matrix is not leaking,top rad hose to hot to hold on to for long,bottom hose luke warm ,both heater inlet and outlet pipes hot,although one was hotter than the other but still no hot air,anyway luckily for me my son is the sales manager for our local seat dealer,so mates rates car is booked in for a thermostat change,well see if it makes a difference
  11. B5NUT
    3,760
    660
    Were the two hoses going into the car hot, these are the ones next to the battery?
  12. yes mate 1 was hotter than the other
  13. B5NUT
    3,760
    660
    That sounds about right, Do you have aircon?
  14. yes and its working
  15. B5NUT
    3,760
    660
    If you have access to vcds then you could check for fault codes, the motors that control the flow of air across the heater matrix haven been know to stick or fail. The first cheap option is to change the stat & the temp sensor. Also if the coolant is looking a little on the brown side then a good flush out and refill with a couple of bottles of G12
  16. Cheers for the replys.gonna change the stat and sender and a flush out.will post the results
  17. ok changed the thermostat today genuine with seal 20 quid,full flush out lots of ****,and whey hey heeeeeeeeeeeeet,the bottom hose is now hot as well no dramas feel lucky that it was that simple,and fingers crossed that was the problem,drove 30 miles heat on and off swapped and switched the air con on and then full heat,90 all the way and oil about the same
  18. B5NUT
    3,760
    660
    Always good to get a first time fix.
  19. update,sunday went to vw fest at hareward house good show,sat on 2.5 miles of non moveing traffic,bricking it in case it over heated,but hey it must of done good now no air locks in system and even on a 3.5 mile journey to work in the morning warm air blowing so deffo seems to have done the trick,2 weeks time on holiday in scotland 300 mile drive a deffo test on reliability
  20. Baza1819
    Baza1819 Member
    254
    I will have to try this then - my heaters a **** poor - saying that the pipes going into my 2.0 tdi sportback are not hot ?
  21. Baza1819
    Baza1819 Member
    254
    Mind fixed
