Heater fan problem
APower Oct 3, 2011
  1. APower
    APower New Member
    Basically when I turn the heat setting to "hi" and fan speed on highest setting the fan will run for a second then shut off:uhm: Any one come across this problem before?
  2. quattro tony
    quattro tony Member
    167
    Not come across this problem tbh, you will have to have a look to see whats going on or get it looked at, could be a fault with the resistor, fan motor ,or a scan may be required of the heater control system to see if any faults logged, does it only happen when its wacked up to max? or does it work ok low and med settings?
  3. APower
    APower New Member
    Yeah only seems to happen when on max
