Heater blows cold
mark7 Aug 12, 2011
  1. mark7
    mark7 Member
    60
    Hi guys. turned the temp up on my climate control tonight and it only blows cold/warm, even on 25 deg its not hot.
    Air con is ice cold, but something certainly not right with the heat side of things.
    Any ideas??
  2. audigex
    audigex Active Member
    594
    45
    How's your coolant level? Was your engine up to temperature?
  3. mark7
    mark7 Member
    60
    Yes. Been driving around a hour, and coolant fine
  4. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,411
    556
    Check your fuses
    Thermostat??
  5. quattro81
    quattro81 All the gear.. No idea
    970
    90
    If you have vcds it's worth a plug in... Could be the motorised flap that switches from hot to cold.. Had this recently in mrs golf...
  6. salad.dodger
    salad.dodger Member
    68
    mine did this, thermostat getting stuck but my temp gauge went up.
  7. Chappy
    Chappy Call me Dan! Audi A5
    471
    25
    I had the same problem last night, although it did eventually start blowing warm air after having it set on HI for a while, I shall monitor it and get it back to Audi if needed.
  8. mark7
    mark7 Member
    60
    Thanks guys. Temp gauge is reading normal, think i'll start with the thermostat then move on from there if no joy
  9. shady-ninja
    shady-ninja Active Member
    999
    53
    if you change the thermostat and the problem persists the it might br the HEATER EXCHANGE MATRIX.
  10. audicruiser
    audicruiser Audi Heaven
    1,865
    Sound like a thermostat to me...
  11. Khufu
    Khufu Well-Known Member
    5,704
    31
    even if its the thermostat jamming open it would eventually heat up. Is it a diesel? mileage? My worst fears concern would be cylinder head gasket being away causing back pressure that stops the circulation of coolant but as gauge is reading fine it could be blocked matrix (feel the pipes in & out of the bulkhead) or a fault with the control panel/flaps as suggested above.
