Heater blowing half and half!
A4sportMrT Nov 11, 2013
  1. A4sportMrT
    A4sportMrT Member
    273
    23
    Hello all, using the blowers this morning and set the temperature which was lovely and toastie my side but the vents on passenger side were blowing cold air. I don't have access to VCDS only a fault code reader of eBay.
    It's literally split down the middle of the centre vent and the one on each side. If I close the vents on passenger side it directs the cold air through the vents my side. I thought I was going mad and had the passenger temp set to low but they were both on the same settings so I'm lost.
    Anyone got any pointers, much appreciated :)
  2. hades-
    9,481
    646
    one of the flaps with be stuck or need a new motor
  3. hades-
    9,481
    646
    or you have the pass side set lower than the drive side
  4. A4sportMrT
    A4sportMrT Member
    273
    23
    Ok cheers, I'll have a look at weekend
  5. hades-
    9,481
    646
    remove glove box
    and you can check the motors in turn and watch for them moveing
  6. A4sportMrT
    A4sportMrT Member
    273
    23
    That's great, hopefully it is just the flaps and not the motor
  7. A4sportMrT
    A4sportMrT Member
    273
    23
    Ok couldn't get round to it last weekend and it was still blowing the same up until tonight where everything was working as it should. Any ideas?
  8. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    Dirty connections to the flap motor(s)? - I found this was the problem when the passenger side was only blowing cold a few months ago. Cleaned the contacts and it's been fine since.
  9. A4sportMrT
    A4sportMrT Member
    273
    23
    I'm still gonna have a look but I'm at brands hatch this weekend, I'm hoping to be able to squeeze an hour or so to get the glovebox out and look. But thing that is puzzling me, is that I've done nothing or altered any settings. Maybe magic :)
  10. Mike B
    Mike B Well-Known Member
    1,101
    40
    Same with mine on the screen vent.Nothing then after trying the switch a few times it came back and has been Ok since.I guess the cogs sometimes don't mesh right but I wont touch it unless it comes back
  11. A4sportMrT
    A4sportMrT Member
    273
    23
    That make sense and sounds possible, I had the blower on full on screen only tonight when I finished work and closed the 4 forward facing flaps. And once the screen was clear I just shut it off and heard it all shut down so perhaps it's sorted it self.
    This was before I realised that everything is now working tickety boo
  12. Mike B
    1,101
    40
    I don't tend to change settings a lot but now I fiddle more cos I think things like to be used and fail more when neglected
