Heater blowing cold and temperature gauge reading too high
TDIQ Jul 1, 2011
  1. TDIQ
    TDIQ 8L > 8P > 8V
    777
    Today I noticed my car crept up to just over 90 to about 100 degrees. It's warm so I didn't think much of it.
    Later on I saw it had gone to 105, this is as high as it read, so I thought I'd try and put the heaters on to take some heat out. The thing is, they blow cold.
    I have run the engine with the coolant cap off and squeezed the pipes to remove a possible airlock, but there doesn't seem to be one. The engine was running, and the gauge was at 90, so I put my finger in the coolant tank and it was warm, but definitely not 90!
    Car hasn't been using any coolant at all, and runs really nicely with no smoke so I'm confident it's not a headgasket, so what could it be?
  2. steve bain
    steve bain Member
    642
    coolant temp sender is a quick and cheap place to start. car has aircon so it works a bit differently i think.
  3. Sandip
    2,440
    91
    Waterpump
  4. steve bain
    steve bain Member
    642
    actually, now you said it, that makes a lot of sense.
  5. S3Lol
    S3Lol Member
    422
    hmmmm, sandip, could this be my issue of running at about 100 degrees?
  6. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    thermostat stuck open ...and a failing waterpump
  7. S3Lol
    S3Lol Member
    422
    well the thermostat is about 2 years old but no guarantee its not messing up. If it was the water pump I would expect the temperature to go straight up. Mine just sits at about 99/100.
  8. TDIQ
    TDIQ 8L > 8P > 8V
    777
    So worst case at the moment is the waterpump? Is it safe to drive back about 30 miles at say 50mph? Obviously keeping an eye on the gauge.
    Cambelt is due anyway so will get it done tomorrow with some luck.
