Heater/aircon stinks
RAW Audi Oct 21, 2012
  1. RAW Audi
    RAW Audi New Member
    19
    Hi there
    as title my heater/aircon stinks of pi55 which dissappears after a short while but recently I've had an intermittent smell of a burning toxic plastic smell coming through the vents when the heater is on. Is there a definitive solution to this and should I be worried?
    Cheers........RAW Audi.
  2. Sandra
    Sandra Moderator Staff Member Administrator Moderator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter
    25,707
    8,790
    Maybe it needs regassed. :) x
  3. Greeny233
    Greeny233 It's all about the V8. Team V8 Team Silver Audi S4 Audi Avant Owner Group
    1,094
    385
    It is bacteria building up in the vents and aircon system. You can get air-conditioning antibacterial spray from eBay or an air-conditioning specialist. Just spray it into the air inlet (where the cabin filter is).
    A little trick I do occasionally is to spray the cabin filter with febreze which makes the aircon smell nice.
  4. scotty76
    scotty76 Well-Known Member Team Phantom Audi S4
    2,869
    1,523
  5. VagPro
    VagPro Active Member
    431
    34
    Also change the cabin filter
  6. twist123
    twist123 Member
    186
    Good luck mate, had this with my B6, no amount of cans of very expensive air con treatment worked. Try running it hot for a while to kill the bacteria, I never found anything to cure it and just had to open the windows for a minute while the initial stink went away.
  7. CHEZ
    CHEZ moderately amusing Supporter
    4,165
    833
    stop turning it off! and it will fix itself! :cool:
    leave it on all of the time! run it very hot for about half an hour, to get rid of the stale bacteria and then just leave it on all the time you use the car! adjusting the temp to suit! normally about 20" in my car!
    mine did the same because i was told it costs fuel to run it, and then it started smelling! i left it on and it fixed itself in about 3 days!
    these are not meant to be turned off but constantly on to adjust the cabin temp.
  8. sidibear
    sidibear Looking for Zombies !! Staff Member Moderator Audi A4
    2,319
    766
    I leave mine on all the time, never really noticed much difference with fuel economy when it was turned off so its left on.
    Cuts out the smelly outside world :icon_thumright:
