Heated washer jets
olds_kool Dec 20, 2009
  1. olds_kool
    olds_kool Active Member VCDS Map User
    1,094
    15
    my heated washer jets dont seem to work
    ive got proper screen wash but washer jets still freeze when its a bit nippy
    do they only work with rear window defrost or something or are they just rubbish or broken
  2. aragorn
    18,612
    872
    Ours seem to be broken too. I'll have a look at the wiring diagrams tomorrow and see how they're connected.
    I know the heated mirrors run off the rear screen demist.
  3. yendall24
    yendall24 Member
    571
    9
    the trouble with heated washer jets is the pipe feeding them freezes thats where the blockage is the jets work fine but with no water being fed to them they are the next best thing to useless
  4. Broken Byzan
    13,237
    466
    They are the same as the mirrors and on all of the time, hence they burn out after time. I need a drivers mirror and both jets.lol
  5. olds_kool
    1,094
    15
    probably are burnt/worn out then, didnt someone look into fitting fan type from later models?
  6. aragorn
    18,612
    872
    My mirrors are defo off the heated screen switch.
  7. floyd 1.8 turbo
    floyd 1.8 turbo Mirror, Signal, Outmanoeuvre
    632
    My mirrors are always on, stupid really. Who needs heated mirrors in summer!! Surely it must ****** something up with all that unnecessary heat??, being on the heated rear screen switch makes perfect sense.
    My nearside mirror doesn't heat up, anybody got a spare they'd like to sell me?
  8. aragorn
    18,612
    872
    must be something they changed over the years then!
    Seems a rather odd retrograde step to me!
  9. olds_kool
    1,094
    15
    my mirrors are on all the time, actually very usefull at clearing rain aswell as frost but washer jets are annoying me
  10. Broken Byzan
    13,237
    466
    All models all on all of the time, facelifts can have a bimetal strip on the back that kick in below 5 degrees ish.
    Even says in the manual they are on all the time
  11. andybnwc
    andybnwc Member
    752
    Same with mine come in really handy. washer jets are on all the time too from what i can tell anyways
  12. AB5QTS
    AB5QTS Member
    228
    9
    Mine tend to freeze and get stuck out. Looks crappy sitting there with the washers poking out.
  13. jcb
    jcb Active Member
    4,132
    13
    50:50 meths is what you need.
    -3 last night and mine was still flowing.
    think my mirrors only come on when the selector is set to the middle, i.e not pointing at a particular mirror
  14. Broken Byzan
    13,237
    466
    Mirriors are on all the time mate. Just the facelifts have the 5 degree strip on the rear of the mirror glass
  15. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    Interesting so i assume the car wont really need to warm up for long to use the jets?
  16. aragorn
    18,612
    872
    unless the solution in the lines has frozen.
  17. Geeman
    Geeman Low Life
    1,318
    Mine are working fine!
    I've just got to remember to move the snow out the way that's blocking them first though!
    They were working at minus 8 yesterday!
  18. aragorn
    18,612
    872
    Well it seems i wasnt imagining things. On a '96 the mirrors are powered from the heated screen switch. On '97> cars, they have they're own permanent ignition feed.
    Our heated nozzles dont seem to work, might have to look at some replacements.
  19. Nige P
    Nige P Member
    65
    Having heated mirrors all the time does seem a bit strange, but you only have to go back to a car without to realise how great they are! I had a new Mondingo hire car a while back and found it almost dangerous as the wing mirrors were next to useless with the amount of water droplets that collected on them.
  20. gruf
    gruf Member
    288
    14
    how do know if mine are worn out, or even if i have heated mirrors.
    Tar
  21. olds_kool
    1,094
    15
    i think they all have heated mirrors?
    touch them see if there warm
  22. mugglesquop
    mugglesquop Member
    62
    i thought they all had heated mirrors. If the car is frosty, do the mirrors defrost quite quickly? only one of mine works :(
  23. gruf
    gruf Member
    288
    14
    how quick should they warm up, if they are worn out how do i fix.
  24. aragorn
    18,612
    872
    gruf: If your cars a '96 they'll only come on with the heated rear screen.
    If they're broken you need to replace the mirror glass afaik, the element is built into it.
  25. gruf
    gruf Member
    288
    14
    tar.
    phoned up, its £30 for passenger and £35 for driver side.
  26. gruf
    gruf Member
    288
    14
    i took glass out and had a look and found that my connectors had gone green from corrosion, i have changed the connectors for new ones and put the glass back but i think the terminals on the back of the glass might be useless coz i had to strain them to get the glass out, i cant be bothered to stand out in the cold to see if the glass warms up so i will let you no in the morning or maybe in a couple of hours if it gets a bit frosty.
  27. rasA4
    3,287
    119
    out of interest, where do they heat from the jets itself?
  28. yendall24
    yendall24 Member
    571
    9
    yes its the jets that are heated but as i have said previously the water freezes in the pipe feeding them so if it cant flow to the jets it cant be heated
