Heated Seat Retrofit - Removing elements from Donor Seats into your existing seats.
Joe90k Jan 21, 2010
  1. Joe90k
    Joe90k Speed doesn't Kill!
    227
    I have missed having heated seats in my A3 this winter from having them in my Golf before.
    As the title says, I have found all the parts to do this, including new seats and climate control for my A3. I am going to dismantle the new front seats and install them into my existing. Has anyone attempted this before? I assume the fabric on the front seats can me removed and the heater elements are only pinned on. I assume this because the elements are a part that is separate to the seat and must be able to be replaced if they fail or short. I did this in my Golf MK4 so it shouldn't be too different.
    I am an auto-electrician by day so I have no problem with wiring etc. I will try to make this into a how to with pictures as I do it.
    So far I have:
    Donor seats (with heating elements)
    Climate Panel with Heated seat switches
    Looms will be constructed using various parts. If anyone is wanting these once I have made the first set I may be able to make others looms for a price depending on the cost of the parts etc.
    Joe
  2. crypric23
    crypric23 Never satisfied
    586
    Why not just put the donor seats in ?
    Or are yours leather and the donor ones fabric?
  3. Joe90k
    227
    Donor seats are all cloth and black mine are half leather with white inserts.
    You have a PM btw.
    Joe
  4. Joe90k
    227
    I'm also doing the retrofit of existing pads as I got the seats cheap and can sell them on after to get some money back. I got the full set black on black cloth with door cards from a 3dr 08 A3.
  5. Khufu
    Khufu Well-Known Member
    5,704
    31
    Do you own ELSA? Its the repair manual & has all the wiring diagrams you will need. This would help show where the wires & possible relay all need to go. It can be downloaded from peer to peer (its huge though) or bought off ebay. All I can say is best of luck replacing the leather & getting it smooth, I've heard its tricky.
  6. Joe90k
    227
    I have got ELSA now so should be quite easy, good idea though. The re-upholstering shouldn't be too much of an issue, my dad is an upholsterer so should be easy enough.
  7. phil76
    phil76 Active Member
    572
    40
    We havnt done this before but have fitted new elements to seats which means stripping them down and to be honest that was a right pain in the clock plus the sponges on the seats we did had clips or locaters to hold the elements in place which i am not sure the seats you have will
  8. Joe90k
    227
    Can the clips be removed from the donor seats? Surely they aren't attached permanently to the foams. I don't mind a pain of a job, I'm sure I've had worse. I had to fit the elements to my golf and it was as you say a pain, took me a while but its worth it in the long run. There are only one part number for the foams, obviously there are different for different seat shapes but the elements are identical for all seats. I'll give it a go, the outlay of it is next to nothing and I want heated seats lol
  9. Khufu
    5,704
    31
    That is handy, I remember a member getting Audi to replace his base cover under warrenty due to wear & it was all mis-shapen!!
    A write-up would be good :)
  10. RobinA3
    RobinA3 Well-Known Member
    1,827
    47
    I looked into doing this including almost buying donor seats but speaking to people at work who do the seat trimmming i decided to bin the idea as getting the seat covers back on all smooth would be an absolute nightmare as you need to stretch them to get them off in the first place and stretch them again to get them back on.
    Good Luck!
  11. gaz4410
    gaz4410 Member
    56
    hi there nice car you have, could you tell me what type of sideskirts you have fitted, and the supplier, would you know if they would fit on my 2007 sline.
    gary
  12. hollow
    hollow Well-Known Member
    1,404
    162
    any one know how to code out the heated seat switches in the hvac unit ?
  13. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,075
    62
    Sorry to hijack your thread, bu I've only got two questions:
    Is there difference in construction (I mean the metal parts inside) between the S-Line seats and standard seats?
    Obviously the shape of the foams is different, but is it possible to put the S-Line leather foams onto standard seats?
