Heated mirrors
jet_andy Nov 6, 2013
  1. jet_andy
    jet_andy Active Member
    168
    30
    Anyone know if the heated mirrors stay on all of the time they're actually switched on? With no indicator light can't really tell - and with previous cars I've had they were linked to the HRW. It's easy to forget they're on.
    Manual says depending on outside temp and roadspeed, but thought I'd seen somewhere about a time limit?
  2. NHN
    29,351
    1,720
    No, they pulse iirc, then after say 10 minutes turn of.
  3. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,562
    1,170
    I believe they just stay on... I keep leaving mine on and forgetting
  4. cuke2u
    cuke2u Well-Known Member TFSI Owners Group Audi A4 S-line owners group saloon
    6,032
    1,774
    Hi, if they are like any other car I've owned they should only come on with the rear screen heater then turn off after a timed amount with the rear screen heater. Seems daft to have them stay on all of the time as most mirrors will demist after a couple of mins...
  5. jet_andy
    168
    30
    They don't come on with HRW - have their own switch.
  6. cemerson
    4,562
    1,170
    Indeed, it's a position on the mirror adjuster / rotary knob.
    The economy screen in the DIS will tell you when they are on, as it shows it as something that uses fuel!
    jet_andy likes this.
  7. A3sportbackMark
    A3sportbackMark Active Member
    711
    230
    43
    The status of the heated mirrors can be seen on the DIS in the Car->efficiency mode menu, scroll to last option I think. this gives a list of things that contribute to eating into your mpg figures.
  8. jet_andy
    168
    30
    Didn't know that, will take a look.
  9. jet_andy
    168
    30
    Almost got a pure Scuba Blue thread....
    cemerson likes this.
  10. A3sportbackMark
    711
    230
    43
    Haha....indeed, just need coolguy and diesel doug!
    c.grex likes this.
  11. coolguy
    coolguy Member
    144
    19
    Here I am. Got me thinking this, still not tried the heated mirrors.
  12. cemerson
    4,562
    1,170
    Good for getting rid of rain as well!
  13. cuke2u
    6,032
    1,774
    Waste of an extra switch then...
  14. Cruiser89
    Cruiser89 Advanced In Car Tech Site Sponsor
    1,484
    222
    Like NHN said...
    They pump full power (100%) on when the car is first started to clear any ice / snow / water and then after about 2mins they will drop down to a constant (7%) power and will pulse every so often.
    When we have done our heated mirror retrofits we always check the logging to ensure it's not over powering etc.
    NHN and A3sportbackMark like this.
  15. dieseldoug
    dieseldoug Member
    240
    53
    I am here didn't get in on time!!
    I just thought they came on when you start the car and time out, as the knob is always left on heated mirrors position.
  16. jet_andy
    168
    30
    Left them on today on journey to work and pretty much fits with Cruiser89's description. Info screen showed them on at all times, but they definitely weren't hot like when you first start (can see rain water steaming off then). But when I felt the mirror it was just slightly warm - could tell it was just a bit warmer than ambient.
    Good to know they're not pumping loads of power in if you do forget them.
    A3sportbackMark and cemerson like this.
  17. A3sportbackMark
    711
    230
    43
    When I put them on, it's so easy to forget to switch them off, as they clear the raindrops so quickly, so good to know their operation.
    Hadn't thought of feeling them for warmth
  18. Silky-S3
    Silky-S3 Is loving his new 8V S3!
    1,407
    343
    So is there a separate switch for the heated mirrors? Or is it like the 8P when the middle setting of the adjustment knob set them to heated?
  19. dieseldoug
    dieseldoug Member
    240
    53
    On my Q5 there is only 3 positions for the mirror left or right, then heated position, again as I said in previous post I just leave it on the heated position.
  20. cuke2u
    6,032
    1,774
    Aha I see now, this is why I need the bloody manual before I get the car. Or just keep my mouth shut :blahblah1:
  21. cemerson
    4,562
    1,170
    There's an additional 'fold mirrors' position as well if you have the folding mirrors
  22. NHN
    29,351
    1,720
    My 8P heated glass works on mine with it set to drivers mirror aswell, that's with rear demister on, whether it works without rear demister is another matter as isn't cold enough yet for them to auto function, although I may check for a temp setting in vcds to see if they work with switch in drivers mirror position.
  23. ddscot
    ddscot Member
    61
    I know what you mean, just got a 63 8v sportback 1.6 tdi in Daytona as a company car a couple of months ago (finally after waiting 7 months) and can't understand why the mirror heat is on the rotary switch, why not a button like the rear child locks?
    My Astra H beforehand just came on with the rear screen heat, not that that is ideal but why the need to rotate the knob so to speak, it can be left on in my case until you realise the reverse isn't working which relies on the selector being left on the left adjust mark, seems a bit weird but there you go, otherwise I love it.
  24. PilotAudi
    PilotAudi New Member
    2,352
    479
    Audi mirror heat typically works when the Rotary switch is in the middle /off position and HRW is on..
    cuke2u likes this.
  25. cemerson
    4,562
    1,170
    I'll test it tomorrow if I remember
  26. PilotAudi
    2,352
    479
    Did it work!
  27. cemerson
    4,562
    1,170
    Ah yes, the 'if I remember' bit...
    Actually I did try it briefly I think, but it didn't work. I'll have to try a longer test at some point, but pretty sure you have to have the mirror switch in the right place for it to work.
  28. jet_andy
    168
    30
    No it doesn't.
    Has to be in the Heat position.
