Heated mirrors not working?
fallmonk Oct 31, 2004
  1. fallmonk
    fallmonk Turbo Sport
    1,868
    Can anyone help? i just noticed heated mirrors aint workin , have checked the fuse box (after a bloody hunt for the thing as AUDI say its on the left ! but its actually on the right!!) fuse aint poped so am at a stumbling block all sujestions are welcome /ubbthreads/images/graemlins/froggie_red.gif,
  2. excursion
    excursion Member
    740
    I do beleive your mirror glass has overheated dear fellow.
  3. fallmonk
    1,868
    didnt know it could over heat ! ok wots my options?
  4. FezzR
    FezzR Member
    86
    if you have a multimeter couple of easy checks,
    one check the voltage supply to the glass
    two check the resistance accross the mirror glass
    normally the mirror glasses tho
  5. ajmackie
    ajmackie Member
    922
    don't they only turn on below a certain temp?!
  6. ajmackie
    ajmackie Member
    922
    don't know. i'm prob wrong!
  7. ajmackie
    ajmackie Member
    922
    in my manual it just says they're only on when ignition is on! useless manual!
  8. imported_ronny
    imported_ronny Guest
    They are prone to burn out, its a **** design.
    They come on when the temp goes below 5c its why there all burnt out, mine was the same, it means every time you start the car, regardless of whether there iced or fogged.
    HTH
    Ronny
  9. DavidR
    DavidR Active Member
    1,296
    You can check whether they are on or off using VAG-COM, and if it says they are ON, and are not hot, the problem is clear.
  10. i had to replace both of my ghlasses as they had burnt out.
    mine coem on with the rear heater.
  11. got them from audi, they werent that expensive.
    just replace the glass, fairly easy to do /ubbthreads/images/graemlins/smile.gif
