Heated Mirror Not Working
Ian W Nov 6, 2009
  1. Ian W
    Ian W Active Member
    1,058
    12
    My drivers mirror isn't clearing in the mornings for some reason. I've tried swapping the connectors but its made no difference.
    Is there a way you can force it to warm the glass so I can check if there is a current getting to it?
  2. jojo
    28,998
    3,652
    Maybe the heating element is broke, it's pretty common. I think if you have the mirror adjuster set in the middle and hit the rear demister button, they come on manually.
  3. 1animal1
    9,978
    i have had this discussion with an Audi tech....he was saying the middle position turns off the heaters (as i had a couple elements break), although both this car and my T plate A3 had the heaters on all the time regardless of switch position
  4. cjhill
    cjhill hmmmmm interesting.
    335
    my heaters are on all the time... adds to great fuel economy !
    I dont think there is anyway of turning them off is there ? seem to be on in the summer too...
  5. Dani_B19
    9,382
    403
    Got the same problem as you mate, really p**s's me off.
    Anyone know how to fix?
  6. Kitchy
    Kitchy Member
    92
    i have this problem with my passenger mirror
  7. Nilz
    Nilz Defo worth the wait :) Team Ibis TFSI Owners Group quattro Audi A4 saloon S-line owners group Manual
    11,367
    908
    Believe the mirror heaters do stay on all the time, eventually causing them to burn out, i think the only option is to get a new mirror glass, to remove the original can be an **** sometimes, as they can shatter, sending broken glass down the side of your car!!!
    I have the same problem on mine, just use my hand to wipe it now..lol
  8. cjhill
    335
    hmmm im quite confused about when they operate...
    Last night the mirrors came on initially when i started the car but when i checked them again (after 40mins of driving) they were off...
    Do they only come on for the first few minutes of driving ?
  9. Dani_B19
    9,382
    403
    I always thought they just came on for the first 5 minutes of the car been armed!
  10. jojo
    28,998
    3,652
    They only come on when the temps outside are 5DeegreeC or below, and switch off when warmed up. They have a built in stat.
  11. Broken Byzan
    13,237
    466
    Pre facelift cars they come on all the time, and facelift cars have a small bi metal temp switch on the back of the glass that activates at around 5 degress or less, but obviously will switch off when it gets warm.
    Its all controlled at the glass so if you really want to you can switch on the ignition and check for voltage with a DVM or a bulb at the two wires in the mirror housing
  12. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    Mine didnt work so I changed the glass...they work a treat now :)
    They're on when the heated rear screens in I think.
  13. 1animal1
    9,978
    im pretty sure there is no link to the rear windscreen heater.... my T plate had them on all the time regardless of switch position or windscreen heater
  14. kevandalice
    kevandalice Member
    69
    facelift cars have them come on at 5C or colder (when the snowflake symbol is shown next to outside temperature on the dash) and with the rear de-mister
  15. 1animal1
    9,978
    you sure Kev? im sure mine come on when its warmer than that..... defo not only when snowflake shows
