Heated Leather?
recomdos Apr 30, 2004
  1. recomdos
    recomdos Active Member
    1,000
    Hi guys (and gals of course), was poking about whilst cleaning the Tsport the other day, and found these little leads hanging from the passenger seat. I was wondering if these are the connectors for heated leather or something - any ideas? They are also tucked up under the driver side too. Fanx! /ubbthreads/images/graemlins/laugh.gif
  2. Mike.M
    Mike.M Well-Known Member
    2,477
    169
    Could be the side airbags or the seat belt tensioner.
  3. recomdos
    1,000
    right.......as far as i know I don't have side airbags....
  4. Ess_Three
    Ess_Three Active Member
    5,383
    12
    As far as I can remember the colour coding of multi plugs goes like this:
    Yellow is Airbags.
    Of this I am certain...plugs for drivers and passenger side airbags are yellow...as are plugs under the seat for side airbags. This is the case on my Mk3 Golf, S3 and my Mk4 Golf Recaros....so I'm certain of this.
    The A3 therefore should have yellow plugs to signify airbag wiring.
    Green is Seat Heating.
    Of this I am also certain...for the newer cars!
    My Corrado's seat heating plugs are black...but again, my Mk4 golf Recaros have green multi plugs for the seat heating elements...as does my S3.
    The A3 therefore should have green plugs to signify seat heating wiring.
    Red, I believe is general power.
    I seem to remember that my S3 has a red plug for general power and earth to supply power to the seat motors...my Mk4 Recaros are not powered, nor is my Corrado VR6 so I can't confirm...but I believe that to be the case.
    Back to the photo:
    I would say from that photo that the seat harness is wired for side airbags...whether or not they are actually fitted (they plug into the seat frame) I can't say...but the wiring appears to be there in the seat frame to support the facility.
    The seat frame also appears to be loomed for power (brown wire)...but depending upon which convention they are currently using...it could be earth!
    But since there are not any other wires in the multi-plug it's not a powered seat...as expected since the seat is indeed not a powered version. This multi plug would have another wire or two if it has electric lumber support, or was fully powered as in the case of an S3.
    As for seat heating...you may well find that the seat is fully equipped with the heating pads...but not the control circuits or wiring.
    My Mk4 Recaros were fully equipped as are some S3 seats - even those where the car does not have the heating seat option fitted.
    To know for sure, remove the seat and look underneath at the multi-plug support panel...if you have a green plug with 5 or 6 wires connected heading up into the seat, you have heating equipped seats...the plug will be obvious!
    Providing you have the plug, and hence have heating equipped seats, you could retro fit using the correct loom & switches. Not cheap though! The handy thing is that it's a simple plug and play set up...plug loom into fuse box, into switches and into seats...and turn on.
    Or, if you have access to the VAG wiring diagrams / drawings, youi could make a loom from scratch.
  5. s3tle
    s3tle Member
    239
    following on from ess the brown is earth and the yellow is airbag wiring. Now i'm assuming that your car is a '98 in which case early in the year ( r reg ) seat airbags where optional and later (S reg) they were standard. If its got airbags there should be a leather tag on the side of the seat saying so and the sides of the seat feel solid. The pic show the connector on a '98 airbag seat which is not heated, corresponds to the plugs in your car, so the earth needs reconnecting
  6. s3tle
    s3tle Member
    239
    airbag seat tag
  7. recomdos
    1,000
    good stuff alonzo! how ya doin anyway? when I popped into the audi garage at thornaby I was a bit disappointed as not only did they not have teh wiper parts I wanted, the chick (was her name charlotte?) was nowhere to be seen! /ubbthreads/images/graemlins/frown.gif I was chattin to Allen on here who's from the north east too, perhaps a little meet in the future sometime? there are a few others too
  8. neil.c
    neil.c Senior
    567
    Looks different to me. The two wires that are in the connector above is one blue and one brown, if so one is the trigger (blue) and the other is the earth return for side airbags, or seatbelt tensioners. The brown wire that is not connected is an earth wire for heated seats and or electric seats, you may have the heating elements fitted but unless you make use of them the dangling earth is nothing to worry about.
  9. Alonzo
    Alonzo Member
    151
    [ QUOTE ]
    [/ QUOTE ]
    Hi Mate,
    Sorry for the mega delay (Just read this now)...Sorry to hear about your wasted trip /ubbthreads/images/graemlins/frown.gif..Future meet sounds good.
    Where are the northern meets usually at?
    Danny
  10. recomdos
    1,000
    will do Danny, damn those corsa's and saxo's! lol
  11. mramage
    mramage Member
    516
  12. mramage
    mramage Member
    516
    Sending you a PM khufu.
