Headlights staying on - No full beam or fogs
gjm Jan 28, 2013
  1. gjm
    gjm New Member
    Strange one, spoke to few who have not came across this.
    VCDS shows 01800 E1 Headlight Switch (implausible signal)
    Tried a switch from another B7 with no auto lights etc and still was the same.
    Wiring all appears good but will be giving it another check.
    Could it be the J519 module just gone bad, it's looking like that but wan't to be 100% before ordering.
    Worth swapping from another car, just a case of keeping the long coding to hand.
  2. hades-
    9,482
    646
    the j519 is an easy swap so if you know someone with same car try it first
    was the switch the same part number
  3. hades-
    9,482
    646
    so do you have auto lights ?
  4. gjm
    gjm New Member
    Cheers for the replies
    Sorry maybe wasn't clear, he car does not have Auto lights and nor did the car I took the switch from.
    Part number of the swtich was identical
    BEZ does J519 need any special coding when changing out or be ok to borrow one and just swap out
  5. NHN
    29,594
    1,782
    Modules do require coding to advise what systems are fitted, but to test someone else's, it may be just good enough to plug straight in, but coding is advised tbh.
  6. stevewr1
    stevewr1 Member
    86
    Same problem here, Did you sort this issue?
