headlights oem halogen
etxeondo Feb 13, 2014
  1. etxeondo
    etxeondo Member
    67
    Does anyone know if you have 8E0941003AK / 8E0941004AK is it possible that you can you swap to 8E0941003BL / 8E0941004BL ?
  2. Wrath
    Wrath Well-Known Member
    1,196
    42
    Are they orange indicator to clear indicator?
  3. etxeondo
    etxeondo Member
    67
    Yes ak is orange and bl is clear, so i want to go from the orange lens to clear lens.
    The only difference i have came across is orange ones use bulb p21w and clear uses py21w but i am unsure if it will it be compatible ?
  4. Oddie
    Oddie Member
    181
    15
    Hi there. I have a set of genuine clear corner headlights for sale removed from a 2007 S Line. Let me know if you want them.
  5. etxeondo
    etxeondo Member
    67
    Thanks, what sort of condition they in ? I still have to find out if they would work and be compatible without throwing a error message and defiantly fit.
  6. ruairi83
    ruairi83 Well-Known Member Team Sepang quattro Audi A4 Black Edition
    1,646
    534
    I've fitted clear corners to my a4 last week and they are done mate..
  7. etxeondo
    etxeondo Member
    67
    I take it you fitted new lights then or did you open up the housing of original ones and remove the orange lens ?
  8. ruairi83
    1,646
    534
    I bought a second hand set of 2007 clear corner light mate.
  9. etxeondo
    etxeondo Member
    67
    I don't mean to be rude, what year is your car as take it the clear ones still had "headlight levelling (electric)"?
  10. ruairi83
    1,646
    534
    Car is 2006 a4 1.9 tdi sline. Straight forward swap an all working fine with headlights aligned.
  11. Wrath
    1,196
    42
    I swapped mine with ones from ebay. Worked without hitch.
  12. etxeondo
    etxeondo Member
    67
    cheers, thanks as i was unsure if possible because of the production number on b7s them clear ones start at and trying to find who makes the lights. I take it Magneti Marelli produce these oem lights or is it Automotive lighting ?
    I will be glad when i have no more terrys orange at the front end.
  13. ruairi83
    1,646
    534
    Automotive light is on both sets mate
  14. hades-
    9,481
    646
    stright swap no errors
  15. Oddie
    Oddie Member
    181
    15
    Apologies for the delay in replying, I've been working away. The lights were removed from my 2007 S Line and are in really good condition. All of the lugs and retaining clips are intact and not broken. Let me know if you want them and we can work out a price.
  16. etxeondo
    etxeondo Member
    67
    cheers for getting back to me, I have since got sorted out with new ones so all the best in getting them sold anyways.
  17. david a4 s line
    david a4 s line New Member
    12
    are your lights still for sale ?
    regards david
  18. Oddie
    Oddie Member
    181
    15
    Hi David
    Yes they are still for sale. PM me if you are interested
