Headlights dimming on startup
jimbooboo Apr 9, 2013
  1. jimbooboo
    jimbooboo Member
    153
    9
    Hi guys,
    Noticed lately that when I start my car for the first 1-2 minutes the headlights go dim and then back to full brightness again. Its quite hard to see sometimes but it is accompanied with a gentle clicking noise from the dash?
    Its a 2006 2.0tdi cabriolet S-line
    Cheers, James
  2. RMH1A4cab
    RMH1A4cab I'm in Cruise control
    549
    19
    Could be the headlight control unit under the steering column, need to go on VCDS first to check voltage to see if it is at fault.
  3. bizzab7
    bizzab7 Member
    102
    have you measured your battery?i had the same problem but it mainly happened when i had my heater on and the lights on at the same time.changed the battery and all good
