Headlight Wiring
stevereid Apr 22, 2010
  1. stevereid
    stevereid Member
    254
    Hello Folks,
    I've had some LED strips i've wanted to fit for a while. My Turbo hose has just come off for the third time in 3 weeks, so while I had the air intake off I decided to have a look at the headlight..when I eventually got the multiplug off...after snapping the little lug that keeps it on..I put a multimeter over the pins and couldnt get any conclusive reading from a specific pin with the side lights on.
    So, does anyone out there know which wire feeds the sidelights ? so I can attach the led's to it, if that makes sense.
    Steve
  2. stevereid
    stevereid Member
    254
    Can anyone help ? Which wire in the headlight multiplug feeds the side lights ?? :(
  3. quattrojames
    14,060
    583
    Most people run them from a wire that's live when the ignition is on, so they are in effect on with the engine. The easiest way to do this is to find a feed in the ecu box.
  4. stevereid
    stevereid Member
    254
    James,
    This was supposed to be a quick and simple mod..and they've been in the boot for months now..I can't find a bloody ignition live in the engine bay.,..anywhere..ahhh.
    Have got door blades on the way tho :)
  5. quattrojames
    14,060
    583
    Surely it must be fairly straightforward to run a wire through into the fuse box?
    What blades are coming?
  6. stevereid
    stevereid Member
    254
    James,
    Electrics have never been my strong point, can fit kitchens, bathrooms..tiling and flooring etc..but never got to grips with electrics !
    I've got some S-line door blades coming, should be here early next week.
  7. quattrojames
    14,060
    583
    I'm with you on electrics!
    The door blades are an easy fit however!
  8. simon.m
    simon.m Active Member
    2,747
    i see on my car some one has run a wire from my ignition live for a none audi stereo they had put in this is not hard to do at all very strate forward.
    just take off the steering colum case then with your multymeter find the ignition live now you can follow this down to a safe point to pinch its feed from the fuse box
    or just tap into it but make sure you put an inline fuse in for the lights.
  9. wallacr
    wallacr Member
    260
    I wired mine up to the headlight adjustment cable, as that's always powered when the ignition is on and of course I used a relay. Can rememer which it was, but can check tomorrow if you need or if you have a meter, just put the ignition on and see which one has power.
    Rich
  10. stevereid
    stevereid Member
    254
    Cheers Rich,
    As much info as poss would be great ..cheers
    Steve
  11. wallacr
    wallacr Member
    260
    Sorry Steve, my day hasn't gone to plan today, so first time on the computer.
    Now I've looked at it I'm not sure if it is the headlight adjustment, I thought it was but I guess it was that long ago I just forgot. Anyway, behind the passenger side headlight lift the small black plastic cover up, you'll see a connector like below:
    Tap into the white & red wire like you can see I have above. I'd just double check it with a meter to be sure it's the right one. I cut the wire and soldered it back together with the additional wire connected and then used some shrink wrap.
    Good luck mate.
    Rich
  12. stevereid
    stevereid Member
    254
    Thanks for all the info Rich, I'll try and have a go at it this afternoon, weather permitting :)
    Is that the headligh multiplug in the picture ?
    Steve
  13. wallacr
    wallacr Member
    260
    It's just behind the light, there's a small reservoirs with a black plastic cover on top of it, lift that cover up and you'll see what I photographed for you. Sorry, I shouldn't have zoomed in so much. I haven't got my car with me, but can take a wider photo later if that would help?
  14. stevereid
    stevereid Member
    254
    Cheers Rich, I'll have a look when I get in tonight/this afternoon.
    Thanks again mate.
    Would did you use to fix the led strips in place by the way ?
  15. wallacr
    wallacr Member
    260
    You're welcome, good luck with it.
    The ones I have had a sticky strip on the back, but I also used a glue gun to put a little glue at each end as I found that it was a bit of a week bond there.
  16. stevereid
    stevereid Member
    254
    Mine don't have any sticky strip, so glue gun it is I think. hopefully this afternoon :)
    Did you just earth them to the chasis ?
  17. wallacr
    wallacr Member
    260
    Yip, I took a bolt out and used one of those washer type connectors.
  18. quattrojames
    14,060
    583
    I'm following this with interest ;)
  19. stevereid
    stevereid Member
    254
    Rich,
    Spent last night fitting door blades..so aslong as the weather up here holds, i'm going to pickup some wire and terminal connectors and have a go at the led's tonight :) With my electrical knowledge, the car will probably be off the road tomorrow :)
    Steve
  20. wallacr
    wallacr Member
    260
    Sure you'll do just fine Steve, good luck with it.
    I'm thinking about some door blades.
    Rich
  21. stevereid
    stevereid Member
    254
  22. wallacr
    wallacr Member
    260
    Thanks for that. Mines a saloon though, so not sure if they'd fit mine. Plus think I best wait a month or so as I've done quite a few mods this month already, lol
  23. stevereid
    stevereid Member
    254
    They would fit :) I know what you mean tho :) I need a turbo pressure hose which is around £50 which wasnt budgeted for...and my wifes tax is due..
  24. wallacr
    wallacr Member
    260
    That's good to know, thanks. It all comes at once.
  25. stevereid
    stevereid Member
    254
    Did you fit a relay to your led lights ? or just wire them live with the ignition ? Pardon my ignorance, but I think i've made it clear how bad my electrical knowledge is :)
  26. wallacr
    wallacr Member
    260
    I did fit a relay, but used that ignition feed I mentioned as the trigger and don't forget an inline fuse, I used a 15amp one in place on there.
  27. stevereid
    stevereid Member
    254
    see, now its getting complicated :) I was hoping to just tap into the live feed and then earth it.. can feel i'm getting out of my depth by the second :(
  28. wallacr
    wallacr Member
    260
    You could do that, a relay isn't totally necessary as those lights should draw too much power, I just always prefer to use them. I'd definitely put a fuse on the positive cable though.
  29. stevereid
    stevereid Member
    254
    Ok, the fuse on the positive I can manage :) Did you power both led strips from the same feed ? (stupid questions..i know) :)
  30. wallacr
    wallacr Member
    260
    Yes I did. Good luck mate
  31. stevereid
    stevereid Member
    254
    Cheers Rich, Going to call at my local motor factors on the way home to pick up the bits :)
  32. wallacr
    wallacr Member
    260
    No problem Steve
  33. stevereid
    stevereid Member
    254
    Rich,
    Sods law, behind my passenger headlight, on the multi plug where you have tapped into the red and white wire..I dont have a red and white wire from that f*cking multi plug, I seem to have the other coloured wires you have and have a red and white wire from the multiplug below, but not as you have :(
  34. wallacr
    wallacr Member
    260
    Nightmare. Do you have a multi meter? Maybe one of the others in there is also run of the ignition.
    Rich
  35. stevereid
    stevereid Member
    254
    Thnk **** for that :) job done..lights fitted and working..The red and white wire was there..just dirty :)
    Thanks Rich for all your guidance and help.
    Steve
  36. wallacr
    wallacr Member
    260
    You're welcome and nice one, glad you found it and got the job done :)
  37. stevereid
    stevereid Member
    254
    They look good, i'll post some pics tomorrow, seeing as its dark now and i need a shower :)
  38. stevereid
    stevereid Member
    254
    LED's..if you can see them
  39. wallacr
    wallacr Member
    260
    Nice one Steve, glad you got them on ok :)
  40. stevereid
    stevereid Member
    254
    Yes,,,eventually :)
