Headlight washer problem
s3mike
After the snowy weather I noticed my driver side headlight washer is spraying towards the windscreen and nowhere near the headlight!
I prized the washer open ( carefully ) and noticed there are two little nozzles to direct the water, or I should say there were two nozzles. I now only have one, wonder if the freezing temps caused the washer fluid to expand and pop it off. There is a circular hole for the nozzle which I assume just clips in but the nozzle is nowhere to be seen.
Anybody had this problem or know if the part is available separately.
I'll ask at the dealer when I get my service done, I guess it should be covered by warranty unless they decide I was using the wrong type of washer fluid or some other twoddle!
Hi
I have the exact same problem but on both head light washer units!
Audi claim that i will need to replace both units as the nozzle type things are not sold seperately!
I think they said about £70 each...I tried dismantlers but hard to come by!
I posted a thread on this before but got no replies .....
Gnic
The jet itself is one unit as you can see here:
Would they not replace them under warranty?
