Headlight Washer/Levelling System Check on MOT - Its Official
NHN Mar 21, 2013
  1. NHN
    29,352
    1,720
    Well obvious from title, but the new regs have come into force from yesterday, mine failed purely because of a hose had come loose & I had temporary disabled the system via coding.
    But, he says if the headlights are hid's, then they have to test for them, he did, failed me because it was disabled, I re-enabled, fixed pipe then & there, passed.
    So you've now been warned, its on the test & any mot station that doesn't check with cars with hid's, will now be breaking the law.
  2. olethalb
    olethalb Active Member
    357
    77
    i need a new pump, mine's seized
    thanks for heads up
  3. ctd
    ctd Member
    106
    will get all those who have retro fitted HIDs without the leveling system and washers, watch this space
  4. Chriscooke
    Chriscooke Clueless!
    509
    25
    Iirc not all cars that came with xenon/hids had the self levelling lights at the beginning. How will they test these?
  5. hollow
    hollow Well-Known Member
    1,404
    162
    I guess your mot tester didnt quite tell you all the rule. If you have xenon lights that have washer jets and self levelling then they must work.if your can has xenoon lights they only illegal if they have an incorrect beam pattern if not fitted with washers and auto levelling . For anyone with aftermarket hid kits if your lghts produce more than 2000 lumens of light then it is a failure unless fitted with auto levelling.
    But if the plod pull you over they cannot fine you /whatever if you state that you're lights only produce 1990 lumens .as they have no way of testing this .only an mot station has the equipment neccesary .
  6. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,820
    197
    Hollow, im pretty sure that was the old rules, if its fitted it has to work, if no level/washer fitted its not tested.
    We will see though, my MOT is up for renewal now too
  7. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,162
    1,123
    Be interested to see what they say.
    I'm going to have chat to my local garage and see what they say.
  8. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,350
    2,888
    Me too. My garage - which is also my MOT testing station - actually supplied and fitted the after-market HIDs I had on my B6 about four years ago. I haven't seen any kits on their shelves for a good while now, so next time I'm in there (service and MOT due end of April) I'll ask them what their understanding is of the legislation as it stands.
  9. @udi A3
    1,820
    197
    I do have manual adjusters from halogen lights still, so should be ok. If not ill be selling some oem xenons soon
  10. jdp1962
    8,350
    2,888
    I just spoke to my servicing and MOT garage about retro-fit HIDs, and their understanding of the current legislation. As far as they are concerned, retro-fit HIDs are an MOT failure, so they they no longer stock, sell or fit them.
  11. wesmaster
    wesmaster Member
    300
    20
    Read here looks like you have to have washers and self level lights for MOT.
  12. Malfuss
    Malfuss Member
    154
    I'm not quite sure how you work that out from your link. It clearly says 'Headlamp levelling and cleaning devices when fitted for HID or LED headlamps'. 'When fitted' is the pertinent part. It doesn't say anything about them having to be fitted.
  13. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    x2 never bothered replacing the pump as the washers just make a mess of the front end and waste loads of screenwash (I buy the fancy nice smelling stuff from VW).
  14. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,913
    166
    I'm pretty sure some older cars that came with factory hids didn't have auto levelling or wash... My old omega for one... *bit of fuel. For the fire right there... * :ninja:
  15. blazedani
    blazedani Guest
    Good point & thanks for the info.
    Most of the people (even some working on the MOT inspection) don´t know that lights under 2000 Lumens don´t requiere auto levelling.
  16. blazedani
    blazedani Guest
    Even the new ones.
    the New Audi A1 & VW Beetle are some examples.
    They have HID headlights (under 2000 Lumens) with no washer or auto levelling
  17. Steve220
    Steve220 Member
    234
    15
    Finally, someone writing the truth rather than knee jerking.
    My old Evo 9 have HID headlights as standard. No washers or auto leveling. It still sales through the MOT as they were never fitted to the car as standard. The main reason this rule has come in is to prevent the use of the aftermarket HID kits being installed and dazzling other road users. I myself do a lot of road cycling and my biggest bug bare is being blinded by incorrect headlight adjustments or HID's.
    Here's one to look up and ask yourself - why must only HID lights have headlight washers? Why not every type of headlight? Answers on a postcard ;)
  18. t8ups
    t8ups Site Sponsor Site Sponsor VCDS Map User
    2,051
    755
    I get dazzled by normal halogens, either the bulb is not seated correctly in the lamp or the headlamp is broke. its soo annoying, and them new Merc Xenons are sooo bright, they should be illegal.!
  19. AR-rkon
    1,913
    166
    As I understand it, Generally because HID (as the name suggrsts) and Led headlamps are far brighter/intense than your usual 55w dip beam halogen, and as such any dirt on the lens can refract the light far more easily than halo's.
  20. ScottD3
    15,162
    1,123
    I don't understand why they did away with head wipers.
    They was so much better than just jets.
    I also thought they was really cool watching the little wiper wipe.
  21. dbm
    dbm Active Member
    636
    186
    43
    Because Xenon lights are so powerful they would melt the rubber!
    A mate of mine works for Leyland Trucks and is up on all the rules & regulations.
  22. ScottD3
    15,162
    1,123
    Really?
    WOW.
    Did not think of that.
  23. cooper86
    cooper86 Member
    61
  24. ScottD3
    15,162
    1,123
    I was thinking about this.
    If the rubber melts, why don't the plastic with in the headlight melt?
  25. cooper86
    cooper86 Member
    61
    I dont think the rubber would melt as hid bulbs are lower watt than halogen bulbs so produce less heat ;)
  26. OFFSKEE
    OFFSKEE Member
    81
    10
    I believe the latest generation of Xenons as fitted to Mercs and some of the other top marques use 55w Ballasts and burners and are very very bright.
  27. Ian2012
    Ian2012 Active Member
    473
    29
    the place where i go just passed one of cars with the wash system disabled, stupid rule if you ask me nice to see common sense being applied, what next your car failed sir because you haven't waxed it recently.
  28. dbm
    dbm Active Member
    636
    186
    43
    Well, that MOT centre is breaking the rules and would lose their license if it was found out. If the system is fitted, is must be operational.
    These rules are for safety - HID lights are very bright and dazzle on-coming drivers very easily. A cleaner lens helps keep that in check.
    Viking likes this.
  29. Greeny233
    Greeny233 It's all about the V8. Team V8 Team Silver Audi S4 Audi Avant Owner Group
    1,094
    385
    Well according to that it just says check operation of any wash or levelling system. So if it ain't fitted it doesn't have to be tested. If its fitted it has to work. That would be my understanding.
  30. Mike B
    Mike B Well-Known Member
    1,101
    40
    Passed MOT again without washers working but thought best to replace faulty pump to avoid future risk.Got to the pump OK but hose was stuck on and had to cut the end off and splice on a section.Will have to watch fluid level now
