headlight washer (a6 2.5tdi quattro, 2000 plate)
abdul h ghafoor Mar 2, 2012
  1. abdul h ghafoor
    abdul h ghafoor Member
    52
    Feeling a bit sheepish as I realised my car has headlight popup washers :idea: . However they ain't popping up or washing. Have checked fuses that was neg, and have tried with headlights on as well which proved neg as well. Any pointers be appreciated.
  2. kite
    kite Member VCDS Map User
    677
    Check the pump on the washer bottle. The washers pop up with the water pressure. If your bottle has low water the headlights washers won't work
  3. ShaunS3
    ShaunS3 Yorkshire & Humber Rep. Regional Rep VCDS Map User
    1,178
    215
    I had the same issue with my S3 that i recently bought. Wondered why they weren't working. My uncle (Motorsport mechanic) came round over the weekend and suddenly got them working, without any tools/diagnostic equipment.
    I did cop the way he operated the stalk though......he plipped the stalk once on, let off, then held up constantly so windscreen was spraying. I was stood at the front of the car at this point and saw the headlamp washers work with my very own eyes.
    Give that a try maybe?
  4. abdul h ghafoor
    52
    Well fixed the headlight washer. Had to access the washer bottle via the n/s front wheel arch. Took the inner cover out held by numerous torx head screws and two bolts. Once removed the washer bottle has two bold holding it underneath. Plus one bolt which u get via the engine bay. I found that the headlamp washer motor connector was loose and dirty. Quick clean and reconected and up they popped squirting away. :icon_thumright:
