headlight scratchs audi a3 2004
khalil May 5, 2008
  1. khalil
    khalil Member
    774
    hi can someone tell me if the lens on the headlights be cleaned use some sort of polish as mine is badly chipped, there not really chips more like very light spot scratch if that makes any sense,it looks like if its got dirt on it,it makes it look really old, any advise any poilshes,
  2. Matt
    Matt Active Member
    1,404
    I think there is a way to do it that involves sanding them down then machine polishing them afterwards but glass is pretty tough stuff to be polishing scratches out of!
  3. khalil
    khalil Member
    774
    do you have i link or something, oh the headlights i belive are plastic or i could be wrong
  4. tjm69
    tjm69 Member
    80
  5. Bell_S3
    Bell_S3 New Member
    Try Meguirs Plast-X. You can even get it from Halfrauds. I've used it on headlight plastic before and after two or three hits by hand the results have been excellent. Also a much safer method than wetsanding.:yes:
  6. WX51TXR
    WX51TXR Polished Bliss
    1,452
    14
    Working by hand, the advice above is very sound with regards to the Plast-X. Working by machine, Menzerna 106FA on a polishing spot pad is ideal and works a treat. :thumbsup:
  7. khalil
    khalil Member
    774
    oh brilliant i knew you would know,but i heard that you need to sand it down bit afraid to do that and thanks all you guys for the tips
