Headlight renewal
Dane Jul 29, 2013
  1. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
    I recently added an allroad to the "fleet" for a good price.
    The headlights were cloudy from the get go, so I decided to sort them out today.
    Before:
    Passenger side:
    P.S. Close up:
    Drivers side - not as bad:
    D.S. close up:
    I followed a similar process to removing the rear tint on the RS
    400 grit W&D
    800 grit W&D
    1200 grit W&D
    2000 grit W&D
    followed by grade 5 and grade 3 wolfs chemicals polish on a Dual action
    Passenger side after:
    Driver side after:
    front on:
    Much smarter I reckon, very pleased with the results. :D
    mrnice and gupsterg like this.
  2. gupsterg
    gupsterg Active Member
    348
    Looks ace mate :icon_thumright: ...
  3. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,912
    164
    Nice work there dane. may have to do this on the (maybe)temporary 2.7 bus... what lamps are those? look different to mine on the same age, are they a FL or just an allroad type?
  4. Dane
    4,086
    182
    could be standard allroad headlamps
    I have washers but they dont appear to be xenons.
  5. adamss24
    adamss24 Well-Known Member
    4,561
    395
    Yes, they are standard allroad lights...i have a6 lights on my a6, xenons !
  6. abdul h ghafoor
    abdul h ghafoor Member
    52
    Nice job. I did the same bought a lense cleaning kit of ebay. Was dubious but cleaned up the lense a treat.
  7. mrnice
    mrnice Member
    156
    15
    Good job!, I'm halfway through doing mine, just finished n/s when my polishing pad exploded, awaiting replacements, few coats of vanilla wax then collinite after is good for some protection, will post up results when finished
  8. mrnice
    mrnice Member
    156
    15
    I finally got around to finishing doing the same on my se-
    before
    durings
    after-
    Just used 1200 then 2000 wet n dry then megs ultimate compound and polish on a pad on an orbital sander,
    then several coats of vanilla moose then collinite wax so they dont go yellow again immediately.
    Was just using what I had kicking around in the garage and the drivers side has crud on the inside so not perfect but better anyhow
  9. adamss24
    4,561
    395
    Best is to put a plastic film over the lenses after you polished the headlights... Good job, need to pull my finger and do mine !
    mrnice likes this.
  10. drfeelgood
    drfeelgood Member
    225
    I used some Megulars plastic RX (I think its called that)with a manual polishing pad, not amazing results but made it a little better
