Headlight removal
blue03 Oct 9, 2006
  1. blue03
    blue03 New Member
    Doen anyone have a guide on removing/fitting the headlights on an 2003 TT roadster? I've searched high and low with no avail.
    Can anyone help?
  2. Rides Remapped
    Rides Remapped Remaps! Get Yer Remaps!!
    Hope this helps....
    BUMPER REMOVAL
    1 ) Jack up, remove front wheels
    2 ) Remove front part of fender liners
    3) Remove the 2 10mm nuts on studs at
    the corners toward the sides holding the
    nose to the body shell. Loosen 2 torx
    bolts holding black side clip
    4) Remove the 6 torx bolts along the top of
    the nose
    5 ) Remove 2 phillips screws at the bottom
    6) Pull nose off, unclip aliens.
    HEADLIGHT REMOVAL
    R emove the 3 TORX BOLTS
    1 ) Remove front one
    2 ) Remove top one
    3) Loosen bottom one (from inside the
    wheel well) and flip support bracket
    out of the way
    4) Wiggle out and unplug
  3. Wak
    Wak Member
    37
