Headlight Refresh
Tooks Jun 8, 2012
  1. Tooks
    Tooks Active Member
    753
    30
    Something has been bugging me about my S3's headlights since I got it, and that is the cloudiness of the headlights. I tried some plastic window cleaner with a dremel, but that didn't seem to shift it at all.
    I read today about kits you can get to clean them up, and googled a few threads about using wet and dry etc.
    Had a look in my shed, found some 2000 grit, and with a bit of nervousness started to rub.
    I only spent about 10 mins on each headlight, and then followed it up with some Brasso.
    Its not perfect, but much improved I think.
    Obligatory before and after pics;
    S3 Headlight Cloudiness by iaintookey, on Flickr
    S3 Headlight Post Clean by iaintookey, on Flickr
    I might give it another go with some finer grit, but they look much better than before anyway.
  2. s33nyboy12
    s33nyboy12 Well-Known Member Audi RS5 Owners Group Navarra Blue Classic
    1,496
    212
    I live 30 miles from Lincoln, you are doing mine for beer tokens lol! No on a serious note ,lies better I wanna try this!
  3. <tuffty/>
    21,873
    4,201
  4. s33nyboy12
    1,496
    212
  5. <tuffty/>
    21,873
    4,201
    ^^^ that :p
  6. Tooks
    Tooks Active Member
    753
    30
  7. <tuffty/>
    21,873
    4,201
    I used Menz Final Finish mostly but had a go with power finish after the 2000grit run to start it off
  8. Tooks
    Tooks Active Member
    753
    30
    Thanks, I'll look out for some.
  9. gareth_oau
    gareth_oau Member
    228
    as far as I'm aware, you also need to apply a UV protective coating afterwards, otherwise they will cloud again very quickly?
    anyone expereienced this, or done it themselves and had no problems?
    I had mine done professionally with a 2 year guarantee on the UV coating
  10. vfr800
    vfr800 Active Member Team Dolphin Grey Audi S3 quattro Audi A6
    775
    57
    Where did you get it done?
  11. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,249
    2,072
    Unless your location of 'melting beans' is down under then it'd be a bit of a trek.
