headlight range control
kanievsky Oct 25, 2007
  1. kanievsky
    kanievsky Member
    Hi
    The headlight range control in my car ain't working. I've checked fuse and it's ok. You can turn the thumbwheel but there is no reaction in either of lights no sound either.
    Any ideas?:sorry:
  2. killa_z
    killa_z Couped Out
    180
    loose wires connecting the lot?
    check the back of yor headlights that all looms are plugged in
    could also check the wired connection on the back of the switch
  3. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    66
    Just a quick bit of electrics fault finding (my job atm btw) if it's both lights not adjusting it'll be nothing to do with the headlights themselves most likely (unless one was at fault and blew the fuse, but you've checked that already). Fuse-switch, switch or switch-loom will be where the fault lies
