Headlight problem
gaz71 Oct 24, 2010
  1. gaz71
    gaz71 1.8T Quattro Sport AJL
    286
    Was just checking to see why my passenger side headlight seems to jump every time I hit a bump and have found that the dipped headlamp section has come loose inside the unit. The main beam section seems ok.
    Can I fix this? (I couldn't see how to get the headlight apart)
    Failing that, has anyone got a spare one?
  2. Tuffty
    Tuffty Member
    127
    the lens' are usually mounted on little ball in socket type mounts. chances are the ball has just popped out.
    From the back of the lamp try pulling the lens towards you and it should pop back in.
  3. gaz71
    286
    So that would be pushing the lens towards the front of the car?
  4. Tuffty
    Tuffty Member
    127
    now you say it it does read that way, what i mean is pull it towards the engine.
  5. Oranoco
    Oranoco Well-Known Member
    3,991
    407
    I have the same thing on me o/s lamp. The plastic scoket that screws to the reflector has broken. Trying to get a dontact for Depo now so I can sort a replacement, don't want to change a whole lamp for the sake of a silly plastic clip.
  6. scotty_audi
    scotty_audi Member
    80
    ive got one for sale if you have a 97 shape b5 let me no if you want it tah scott
  7. tonya4
    tonya4 TDi Powerrrr
    408
    i've got a facelift light if you need one.
    tony
