headlight conversion from 2009 halogen headlamps to s3 led bi xenon
s3_ity Jul 21, 2012
  1. s3_ity
    s3_ity New Member
    17
    HELP needed as i dont have a clue sorry.
    hi
    i have an 2005 audi a3 3.2 quattro s line, i firstly got the front end conversion done to the new 2009 model with the normal halogen headlights. i now have purchased some s3 led bi xenon headlights however after buyin them was told they are from germany however they are genuine and are from the dealership. i now need to know how i go about doing this as i have been told if i fit them my wiper motor will burn out. from what i gather i need to just get the kufatec adapter and then recode them and also sort out the levelling as they are from germany..... is that correct???
    plz help im totaly lost
    thank you very much for your help in advance :)
  2. N8
    17,163
    719
    First of all your headlights will be LHD. You want UK headlights and if I were you, I wouldn't use Kufatec, I'd use someone like NHN to wire them in correctly. He's done lots of work on my car and I highly recommend him.
  3. s3_ity
    s3_ity New Member
    17
    i have been told that you can get them adapted for use in the uk, and alsop will i need to buy an auto levelling kit and the washer system or do the lights already have it. do i jus need to plug the lights in withe kufotec adapter and recode the lights
    sorry if im not makin sense lol
    (i did try to get in touch with nhn but had no reply)
  4. PH1L
    PH1L Gievf Buckets
    3,851
    40
    you cannot get them adapted, not to pass MOT anyway, you need uk housings, as for the kufatec loom i wouldnt bother, get nigel to sort you out, you will still need a new ce unit and a new headlight level unit
  5. KemiksiZ
    KemiksiZ Active Member
    570
    142
    43
  6. s3_ity
    s3_ity New Member
    17
    Hi n8 any contact details for nige and his location I'm from aaround manchester
  7. PH1L
    PH1L Gievf Buckets
    3,851
    40
    nige will come to you, best way to contact him is via pm, give him time to get back he is a busy man
  8. N8
    17,163
    719
    His user name is NHN. PM him.
  9. s3_ity
    s3_ity New Member
    17
    Thanks ppl :)
