Headlight Bulbs
reynot01 Jan 24, 2005
  1. reynot01
    reynot01 New Member
    20
    I have just sold my Seat Leon Cupra R and am getting an 02 A4 1.8 T Sport. I was wondering, would my H1 and H7 Osram silvastar bulbs that I had on the Seat fit my new car?
  2. imported_Macduff
    imported_Macduff Guest
  3. reynot01
    reynot01 New Member
    20
    Cheers Dave
  4. phil1978
    phil1978 Member
    183
    Yeah, that's correct Macduff. And they are a bugger to change, i've got the grazed knuckles to prove.
    But I've now found out a better way to stop all of that !!!!!!!!!!!!!
  5. reynot01
    reynot01 New Member
    20
    [ QUOTE ]
    [/ QUOTE ]
    Intersting, care to elaborate? I don't like grazed knuckles either /ubbthreads/images/graemlins/cry.gif
  6. phil1978
    phil1978 Member
    183
    There is two more torx screws at the bottom back of the headlight. Loosen these off, but dont fully undo them. Once the two from the top have been removed the whole unit can be removed from the car.
    = easy bulb change. YIPPEEEE
  7. phil1978
    phil1978 Member
    183
    The ducting on the drivers side requires you to undo two screws on the front slam panel, then with a bit of manipulation you can take this out allowing easy loosening of the rear screws. I'll try to post some pics of the rear screws for you tomorrow. But they are easily visible. One is on the back corner nearest to the middle of the car, and the other is about three quarters of the way along the headlight towards the wings.
    Hope this helps.
  8. phil1978
    phil1978 Member
    183
    Tim,
    I've emailed you the pic.
    Hope this helps.
    Phil.
  9. Any chance you could post the pics on here Phil.
    The warning flashed up on the DIS last night 'RIGHT DIPPED HEADLIGHT'
    It sounds like a pretty daunting task just to change a bulb!
    Deano
  10. phil1978
    phil1978 Member
    183
    DeanoMorph,
    It's not daunting at all mate. All it is is the four retaining bolts then the headlight pulls forward, be careful not to scratch your bumper ( I used a tea towel ) Then you can get to the covers and remove/change the bulbs easily.
    DONT remove the two back bolts fully, just undo them enough that it allows you to slide the headlight forward.
    Be lucky.
  11. phil1978
    phil1978 Member
    183
    Deano, I cant get the pic to upload, so PM me your email and I'll forward it to you.
  12. Cheers for that mate. Check your inbox!
    Thanks again...
  13. scoTTy
    scoTTy Active Member
    1,962
    This may help in the future :
