headlight bulb change
marktdisport Dec 20, 2011
  1. marktdisport
    marktdisport Active Member
    1,195
    15
    Hey folks tryed a search but nothink comes up..... my headlight bulb as blown tonight, my question is how do you get access to get them out ????  thanks
  2. quattrojames
    14,068
    585
  3. unitzero
    unitzero Bagged B7 170 TDI Avant Audi A4 Black Edition
    568
    198
    43
    I was also at a loss after popping the bonnet and looking round there for a good 10 minutes, but after taking a look around - found a great step by step guide (similar to the one James posted above) to removing the headlamp and it was a piece of cake after that. (only needed to do the drivers side though)
  4. marktdisport
    1,195
    15
    perfect info thanks guys, was screw no2 i couldnt see
  5. quattrojames
    14,068
    585
    DON'T remove the two lower screws, just slacken them off.
  6. marktdisport
    1,195
    15
    thank james funny i ordered some new bulbs last week some osram night breakers, but didnt expect one to blow tonight the bulbd havent arrived yet either
  7. Cabbyfan
    Cabbyfan Active Member
    840
    34
    Tape the top edge of your bumper as well so it doesn't get scratched.
  8. crazy88
    crazy88 Loving the anonymity
    4,939
    438
    Thanks for that tip :) will be doing that when I do mine
  9. PhilW
    PhilW Member
    182
    Normally i would say people are nuts to remove a headlight to fit a bulb but on an A4 its like a 2 minute job which makes the whole thing sooo much easier.
    Might be worth checking your headlight pattern against a wall before and after to make sure its adjust correctly after removing it.
  10. mikeh126
    mikeh126 Member
    152
    Very good advice. I've just changed my bulbs to xenons. Unless the headlight is pushed firmly all the way in at the bottom, the headlights end up, like mine, pointing at the tops of the trees!! So, had to slacken the torx 30 bolts again, and re-adjust.
    Also - changed the sidelights to 8 LEDS each side, and the fog lights to Nightbreakers. Vast improvement!!:yes:
