Headlight being weird as ....
wuta3 May 15, 2013
  1. wuta3
    wuta3 Well-Known Member
    1,131
    347
    My right self-leveling-main-beam-projector-headlight-thing turns off with dash bulb warning when driving over a bump occasionally. The sidelight remains on, so it isn't power being cut to the unit. If I turn the headlights off and on again, the right one always comes back on immediately.
    The unit connector seems fine, no water ingress to the unit as far as I can see. Any ideas?
  2. JRock247
    JRock247 Active Member VCDS Map User
    662
    88
    Could be the bulb on the way out, have you got a spare to try?
    Do you have auto lights installed?
  3. wuta3
    1,131
    347
    No spare bulb, not auto lights (as in the ones that switch on auto), its just 8P2 lights. It has been doing it for over 6 months, i'd have thought the bulb would be ok. What bulbs do the projectors take?
  4. NHN
    29,524
    1,766
    What headlights are fitted, halogens or bixenons?
  5. wuta3
    1,131
    347
    Nooo idea. I just know they are this type:
    1297899831_72235657_3-FAROL-Bi-XENON-E-DIRECIONAL-AUDI-A3-8P-ANO-2007-Pecas-e-acessorios-carros.jpg
    So would that be bi-xenons?
  6. NHN
    29,524
    1,766
    Bixenon Aiden, so I would consider 2 options, swap bulbs across & see if fault follows, if doesn't follow then try swapping the igniter modules across, at least this way it will work out where the issue lies & replace the item at fault.
    D1S are the bulb type.
    wuta3 likes this.
  7. wuta3
    1,131
    347
    Perfect, cheers. Didn't think much was swappable, will give it a go.
  8. NHN
    29,524
    1,766
    No worries, better sort these rear lights out now huh lol, just stepped of a plane so little slow today.
  9. wuta3
    1,131
    347
    Sorry mate, had to go through TPS in the end as had a potential buyer on the old ones. Then the buyer pulled out ... what a pain in the **** :(
