Headlight beam pattern and Xenons
cyberdude May 19, 2004
  1. cyberdude
    cyberdude Member
    31
    Since getting my 2000 A4 in December I have been dissappointed with the performance of the headlights. After reading the forum it seems that the general perception is that the A4 H7 lights suck. I am thinkng of installing Xenons but am wondering if it will make that much difference.
    Are the standard h7 lights bad because they are not bright enough or is it because of a bad beam pattern? They certainly don't seem as bright on the road as some other cars (really noticable when passing another car - their lights seem a lot brighter on the road).
    I don't want to go to the trouble and expense of installing Xenons only to find it has not made much of a difference. Will I just need to replace the bulbs and add the ballasts or is the actual projector lense different too?
  2. Jonc
    Jonc Member
    71
    I've swapped the standard h7 bulbs with Osram Silverstar 50% bulbs. There is a big improvement and not too far off HID Xenons. The projector lights cast a very defined beam on the road and does take getting used to but is no worse than other normal halogen lights of other cars. I've adjusted the beam to point slightly higher up so the "cut off" is further away and therefore lights up more of the road.
  3. JaceyBoy
    JaceyBoy New Member
    17
    Na HID will be far better, but get 6000K
  4. JaceyBoy
    JaceyBoy New Member
    17
  5. PaulRS3
    PaulRS3 Well-Known Member
    1,218
    150
    HID upgrades are largely illegal and will fail your MOT.
    there are lots of threads on this, and in one of them a specific response from the DOT.
  6. Jonc
    Jonc Member
    71
    Cyberdude, adjustment for your high beam should be separate from your dipped. The osram bulbs are alot cheaper, and while obviously not as good as HID, they are a lot better than standard IMO. Will you notice several hundred pounds worth of improvement with HIDs? well having owned a car with HID, not really unless you have cash to burn.
    Check this links out to find out how to align your headlights
    http://www.autooptiks.com/aiming.html
    http://www.dimebank.com/Light-up.html
    http://www.advanceautoparts.com/howtos_tips/automedia_html/ccr/ccr20010801ha/index.html?page=/howtos_tips/automedia_html/ccr/ccr20010801ha/ccr20010801ha.htm
  7. cyberdude
    cyberdude Member
    31
    Great JonC. I'll try a pair of the Osrams and see how they are. I'll also carry out a headlight alignment on the weekend if I get time. I wasn't aware that the high beams could be adjusted independantly of the low beam. when I looked under the bonnet I only saw two adjustment screws - for vertical and horizontal adjustment.
  8. cyberdude
    cyberdude Member
    31
    JonC, where did you get your Osrams from and what did you pay? I live in Portugal and have not been able to find them here. I've also searched the net and found prices vary wildly. So far the best I have found is £27.90 for a pair. Is this about right?
    I am also a little confused and want to be sure I am looking at the right bulbs. I have seen the Osram Silverstar 50% (H7 12V 55W Osram Silverstar 50%) being referred to as Xenon replacement bulbs. Are these only ment for Xenon (HID) systems or is it the replacement for the stock halogen H7s I am looking for? Just found a s set for £22.90.
  9. Jonc
    Jonc Member
    71
    I got mine from www.powerbulbs.com for around £28. You should be looking at Osram Silverstar 50% H7 as you described. They are only xenon in the fact that the gas used in these halogen bulbs contains, amongst others, xenon to allow the filiment to burn hotter and brighter. These aren't to be confused with HID Xenons that don't use a filiment but an arc of electricy between 2 electrodes as the source of light.
