Headlight beam adjuster broken
gavsman Jan 24, 2012
  1. gavsman
    gavsman Member
    379
    Hi Guy's, car has just been for an MOT & has failed on the one of the headlights being out of allignment, I have taken the unit out & looked in the back, the problem appears to be the ball & socket adjuster has broken ( the socket is the broken bit ) probably from the previous owner over adjusting the headlights till it snapped.
    the question I want to know is....... can this part be purchased or do I have to get a new headlight?
  2. jbcalvin
    jbcalvin Member
    691
    21
    Depends on what part is broken, is it the part that is attached to the lens, or the part attached to the adjustment motor, if it is the motor part, that can be replaced on it's own, if not, new headlight....
  3. quattrojames
    14,050
    576
    I can't quite visualise the bit you mean. Does this help?
  4. gavsman
    gavsman Member
    379
    Looks like parts 5 & 6 it is the socket which holds the ball part of the adjustment screw that is broken
  5. quattrojames
    14,050
    576
    Part 5 is Headlight Range Control Motor - 1JO 941 295B
    Part 6 is an O Ring - +443 941 323
  6. marktdisport
    marktdisport Active Member
    1,195
    15
    is it defo broken or just the ball joint popped out, noticed mine had popped out other week when i changed my headlight bulb
  7. gavsman
    gavsman Member
    379
    Yep deffo broken, the nut that the ball pops into has been snapped in half, so the ball does not click into place.
  8. gavsman
    gavsman Member
    379
    Decided to just buy a new headlight as it was cheapish
