headlight adjustment
mark.colledge Aug 28, 2010
  1. mark.colledge
    mark.colledge Member
    76
    hello guys,
    i need to adjust my headlights down, i know how to adjust the height of them i was just wondering if anybody knows the setting number it should be on. my mot retest is on tuesday so get checking on your a3 :)
    Thankss :)
  2. Broken Byzan
    13,237
    465
    Set the interior knob at 0 before aiming the headlights
  3. mark.colledge
    76
    ok thanks, do you recon it will pass the mot if it stays at 0?
  4. Broken Byzan
    13,237
    465
    0 is the highest setting and it's where the MOT man will set the lights before checking the alignment
  5. mark.colledge
    76
    ahh rite. do you know what the actuall number setting in on the actualy light itself, i do beleive there are numbers on the outer side of the normal headlight?
  6. Broken Byzan
    13,237
    465
    AFAIK theree are no numbers on them, maybe an 8P expert can tell you different. But tbh its not good you setting it the same as someone else as the light could be fitted slightly differently, or your suspension different
