Headlight adjuster screw/cog
Rs6mick Apr 25, 2013
  1. Rs6mick
    Rs6mick New Member
    27
    Hi people looking under the bonnet of my s3 today and noticed one of my headlights is missing the screw and cog that adjusts it so I thought I can just buy them from Audi but looking at the etka online on the web and it looks like you cannot buy them on there own can someone please help me or point me in the right direction
    thanks
  2. Dan-Jnr
    Dan-Jnr Well-Known Member
    1,234
    386
    I had this problem too, the garage who did my MOT managed to stick a nut on the adjuster.
    Audi will want to replace the whole headlight if you let them touch it.
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
  4. vfr800
    vfr800 Active Member Team Dolphin Grey Audi S3 quattro Audi A6
    775
    57
    Hi
    I assume you're left with this
    Cos this has fallen off?
    It's a bummer.
    There is a thread somewhere on here where someone mentions where you can purchase this type of bevelled cog from. I think it was HPC Gears Home page I was going to send them a sample one and they'd make one that would fit.
    Unfortunately without this cog the head lights flap up and down when you go over a bump and you cannot (obviously) adjust the lights.
    Liam
  5. Slammedorion
    Slammedorion Active Member Audi A3
    251
    78
    Pull it out as far as possible and put a thick zip tie round it... :yes:
  6. Sam_
    Sam_ Down under
    3,038
    480
    Aren't you supposed to calibrate the lights in VCDS and not really touch those? I just re-calibrated mine after sorting the front and rear sensors and it's miles better.
  7. vfr800
    775
    57
    No, VCDS calibrates the motorised level adjusters. That puts the motors in theirs default home or middle position.
    you then use the manual adjusters to aim the lights where they should be pointing.
    the motors merely move both lights up or down a bit to compensate for the loads in your cars, Thats why you have sensors on the front and rear wheel. So that the car knows if there's more weight in the front or back.
    liam
  8. Sam_
    Sam_ Down under
    3,038
    480
    Ah ok. It is also possible to change the home/default position in VCDS too, if needed.
  9. rhys1210
    rhys1210 Active Member Team Meteor Team V8 VCDS Map User Audi S5 quattro
    177
    26
    I had the cog missing on mine. i just went to a scrap yard pull one off of a car and fitted it to mine.
