Headlamp Washers
c16wko Feb 21, 2008
  1. c16wko
    c16wko Member
    71
    Ive just noticed mine aint workin no more? Any common things to look out for? :think:
  2. White220
    White220 White 220
    64
    When your fluid level is low, indicated by the annoying beep noise every time you start the car, the headlight washers no longer spray the headlights but you will continue to have windscreen wash for another week even in salty road shires!!!
    Just a thought....
  3. c16wko
    c16wko Member
    71
    lol yeah thers pleanty of fluid in there.
  4. jcs356
    jcs356 Brum brum
    2,725
    65
    When you say they aren't working do you mean that they pop-up but don't spray, or that they don't pop up.
    The water pressure is what pops them up, so worth checking if you have a leak in the system (puddle under the car should be obvious). Also possible that if they haven't been used in ages then they have just got gummed up with road grime. You can prise them up out of the bumper with your fingernails and check they operate freely.
    Seem to remember that you are supposed to use a certain washer fluid as well as the pipes are quite narrow and so can get gummed up with residue.
  5. c16wko
    c16wko Member
    71
    yeah they dont pop up. only been over last few days. worth checking hoses then and check movement ...
  6. sitrials
    sitrials Member
    872
    DITO mine have just done the same bumper is coming off at weekend so i have a look at the pipe work. also the covers have become very loose not like they used to be maybe not retracking correctly??
  7. chesney
    chesney Member
    37
    Check the 20 amp fuse. I think its in position 33. Mine blew when we had sub zero temps up here and the pop ups had frozen to the bumper.
    New fuse and they've been fine ever since. Worth a check and cheap!
  8. sitrials
    sitrials Member
    872
    checked the fuse if that had blown the windscreen washers wouldn't work at all!
  9. c16wko
    c16wko Member
    71
    Will check that now ...
    cheers :icon_thumright:
  10. c16wko
    c16wko Member
    71
    :respekt: just nipped out to check fuse. sure enought, fuse 33, 20amp, popped!
    cheers pal. saved me hours of chasing hoses out
  11. S3 NIK
    S3 NIK Member
    190
    Am i alone in thinking they are pointless, only help in using washer fluid far too quickly.
    Nik.
  12. c16wko
    c16wko Member
    71
    i have to dissagree. i noticed mine wer not working because the lights seemed really dull. i find they help alot in poor weather. each to their own though.
  13. S3 NIK
    S3 NIK Member
    190
    Wash your car more often :)
    Nik.
    Only kidding........
  14. c16wko
    c16wko Member
    71
    ha in this weather, no chance lol :sadlike:
  15. S3 NIK
    S3 NIK Member
    190
    I know what you mean. My car is dark blue, the wifes mini is black but both look a strange shade of white at the moment.
    Tomorrow calls for a washing session to get rid of the salf before it eats its way through the paint!!!
  16. 2low4u
    2low4u Active Member
    199
    42
    is there any way you can switch them off? i hate the streaks they leave on the bonnet!
  17. chesney
    chesney Member
    37
    I suspect you may have washed your car and it's then frozen over. Thats what happened to me.
    Glad it worked for you:icon_thumright:
    As for sitrials sounds more serious and hope its not too much hassle to fix. Electrical faults can be a real pain. My Pug 205 drive's me nuts:wacko:
  18. c16wko
    c16wko Member
    71
    well id assume just remove fuse 33 lol. :meeting:
