Headlamp washers
AR-rkon Feb 8, 2012
  1. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,913
    166
    Best way to transfer my washer jets over to a FG RS4 bumper? Dremel and epoxy, sikaflex etc???
  2. Bradderz_1988
    3,958
    240
    The headlight washer are mounted to the bumper crash bar iirc so you will just need to cut out the holes so that the washers sit flush with the bumper.
  3. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,164
    1,123
    I think Foxmeister has alot of images in his build thread about it.
  4. Foxmeister
    Foxmeister Fired Up!
    1,785
    Yep, both Bradderz and Scott speak the truth!
    I was looking into doing it with my RS4 Rep bumper until an oem unit became available and i went that route! The concept is, for all washers other than oem RS4, the washers unit/caps are pushed up with the pressure and then rest back on the bumper itself, so in reality you only need a hole big enough for the washer jet to get thru, but less than the width and breadth of the cap so the bumper still supports it when retracted!
    I still have my original Sport bumper here with the holes, i can measure sizes if you need it but im sure it'll be obvious when you start doing it!
  5. aragorn
    18,545
    865
    Facelift A4's are like the RS, ie the washers are recessed into the bumper.
  6. AR-rkon
    1,913
    166
    well i can either:
    • Use PFL wash jets and get colour matched.
    • use surface mounted ones (like these: Wash Jets)
    thoughts? as i think FL ones will be tricky to make them fit correctly.
  7. AR-rkon
    1,913
    166
    Could use some from a 2003> laguna and just paint to match the front bumper?
  8. AR-rkon
    1,913
    166
    What would be the tidiest/easiest route in your opinion guys?
    PFL ones or use some like the mk2 laguna where they are always visible on the bumper?
  9. ScottD3
    15,164
    1,123
    PFL flush units.
    Look so much better.
    Don't they sit or clip on top of the jets?
  10. AR-rkon
    1,913
    166
    think the cover clips to the top of the jet head.
    Now to find someone who is breaking a PFL and will part the jets and pipework out of the bumper.... hmm
  11. ScottD3
    15,164
    1,123
    I can't remember if its the PFL or FL that has the flush units. But they are deffo the best.
    Any of the breakers what you after?
  12. ScottD3
    15,164
    1,123
    I had a thought.
    No idea if it will work.
    But if you're after a flush subtle look.Check out BMW's rear washer jet for the their E34 tourers.
  13. Foxmeister
    1,785
    Explain Scott....with pics for simple c*£ts like me!:uhm:
  14. ScottD3
    15,164
    1,123
    You'd only forget.
    Ok then.
    The ones in the tail gate are small round flush fit the eject up to squirt. Same out head light washers but they are smaller and flush fit.
    I'm not fully 100% sure how they work, attach or their size. This all from memory of when I had mine and I never worked.
    I'll find more info and pictures tomorrow for you.
