Headlamp washers not working anymore
Lemon S3 Jan 22, 2014
  1. Lemon S3
    Lemon S3 Alex
    1,390
    41
    My car has failed it's MOT due to the headlamp washers not working so need to sort it asap. They used to work fine, I've checked the fuse n it's ok, you can hear the second pump come on but nothing happens. I've just taken the bumper off to check for splits but can't see any leaks, I've taken a pipe off and water flows out but doesn't increase when the second pump comes on. I've had a search and read a few threads but no one appears to have had the same issue as me, so if anyone has any insight, I'd appreciate it.
  2. epox
    epox Active Member
    772
    74
    Sounds like the pump, try extending the washer pipe to above the height of the washer bottle and try the pump does not push the water out I would say it’s the pump.
    if you have an air line you can disconnect the hose at the bumper, connect to the hose and check the h l washers pop up.
    mark
    Airs likes this.
  3. Gary_808
    Gary_808 Member
    166
    Mine didn't work,
    So I gave them a tug and pulled them out and they started working again after that.
  4. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Lights have to be on remember... and it has been cold the last couple of nights maybe they are frozen?
    If not as above try get them working manually they may be just stiff..
  5. Lemon S3
    Lemon S3 Alex
    1,390
    41
    Well the pump was working but not connected to the impeller as the casing is cracked at the top, so the pump had risen slightly and disconnected itself. Put some sikaflex round the pump and clamped it in place with a jubilee clip and it's working perfectly now. Passed it's MOT today as well so I'm happy :) ImageUploadedByTapatalk1390433310.439382.jpg
    StaceyS3 and s3dave like this.
  6. Nilz
    11,331
    881
    Result!!
  7. Ian2012
    Ian2012 Active Member
    473
    29
    Hmm i wonder if that's the problem with , they are £60 quid or so from audi!!!!!
  8. vfr800
    vfr800 Active Member Team Dolphin Grey Audi S3 quattro Audi A6
    773
    57
    You can get a replacement febi bilstein one off ebay for about £17 - i've had one on mine for a year without and problems.
  9. Ian2012
    473
    29
    Thanks for that will get one asap
  10. russwuss
    russwuss Active Member
    549
    106
    43
    apart from the OP, has anyone else failed a MOT on this? I took my front bumper off to fit the FMIC and noticed the hose for the headlight washers had been plugged up :-/ looks like it's been plugged up for a while as the hose clip was extremely rusty..
  11. Ian2012
    473
    29
    I will report back tomorrow with what the mot man says..
  12. Blackheart
    Blackheart New Member
    Legally speaking, if the car has factory xenons then it has to have headlamp washers. Actually have talked to a couple mot fellas about this specifically. Though in my experience some notice them and some don't :D
  13. Ian2012
    473
    29
    Well it passed today with no advisories!
    russwuss likes this.
