Headlamp washer jets
bpnike Jan 15, 2014
  1. bpnike
    bpnike Member
    Hi guys,
    Maybe a stupid question but..... do your a3 sportback's with normal headlamps (not xenon/led) came with headlamp washer jets?
    My one has the covers on the front bumper but i havent seen them working yet. i have checked if the pumps are installed but could not see much....
  2. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,371
    1,063
    I would imagine they wouldn't come with them for the halogen lights as they aren't a requirement. The panel are probably only there to avoid having to make twice as many types of front bodywork!
    blazedani and SlightlyYapper like this.
  3. NHN
    29,284
    1,695
    Actually some are fitted with washers, seen other chassis with washers on halogens, its not solely with xenons, think its something you can request.
  4. cemerson
    4,371
    1,063
    Perhaps it's an option in other countries
  5. NHN
    29,284
    1,695
    On RHD cars fella in UK :)
  6. Schizophonic
    Schizophonic Well-Known Member
    770
    378
    If I plug Vcds into my car, how do I know if washers are installed?
  7. cemerson
    4,371
    1,063
    Pull the stick and see if they pop out? :p
    TonyH38 and NHN like this.
  8. NHN
    29,284
    1,695
    Urm that's left very open to a reply lmao.
    cemerson likes this.
  9. Vertigo1
    Vertigo1 Well-Known Member
    3,381
    542
    As above - turn your headlights on then wash the windscreen. Don't worry about not being outside to see them working - you'll know as the bonnet will get covered in spray :)
  10. Scott
    Scott Well-Known Member
    1,306
    126
    Oh don't mention headlight washers or you'll have the headlight washer police on your tail
  11. h5djr
    9,197
    1,586
    You can always tell when they operate because the headlight beam goes 'strange' for a few seconds.
  12. Scott
    1,306
    126
    Mine goes 'strange' for a lot longer than a few seconds. I noticed a distorted beam for several miles in slow traffic
  13. h5djr
    9,197
    1,586
    I've only ever noticed any difference in the beam whilst the water is actual being sprayed on to the lens.
  14. Scott
    1,306
    126
    I'll try and get a photo sometime. It was very strange with the full LED's. I haven't noticed it before with the xenons, apart from when it was actually being sprayed.
  15. h5djr
    9,197
    1,586
    Could it be because the with Xenons the front lenses get quite hot and the water dries very quickly whereas with LEDs the lenses don't get so hot.
  16. Itguy
    Itguy Well-Known Member
    1,130
    449
    Interesting - on our Golf GTI I notice a shimmering on the beam pattern for a few seconds (10-20 maybe) after a headlamp wash.
  17. h5djr
    9,197
    1,586
    It the system used by VW on the GTI the same as used by Audi on the A3 I wonder. I look at ETKA required I think !!
  18. ddscot
    ddscot Member
    61
    Mine spray twice when triggered and you can hear the motors going easily, one big spray after the windscreen followed by a smaller one, it does go all over the bonnet/screen and I do notice a bit of a "vertical line" effect going on with the beams after they wash due to the water sitting on them, they don't do it every time though but most times if I haven't used them a lot then first time it will.
    Perhaps it's made worse or better by certain screenwash, im just using halfrauds low temp winter gear at the moment although the cold has yet to appear this year.
  19. Itguy
    1,130
    449
    I would imagine the washer system on our GTI is similar in design to the A3 8V - there aren't that many different ways of doing it really. The little stalks with the washers on get forced out under water pressure and are not motorised themselves. It's the pump that you hear "whizz" and then it pumps high pressure water to the headlamp washers which pop out and spray. The timed relay switches the headlamp washer pump on/off to create one or more sprays.
    Our GTI only sprays once (not a double spray) and then waits for X minutes or 5 normal windscreen washes to spray again
  20. h5djr
    9,197
    1,586
    I must admit on my 8P I don't seem to get spray on to the bonnet. I tend to use Audi's own screen wash. I have used other types but found the spray onto the windscreen is not so good and the gets have blocked. I assume the GTI still has the fine spray onto the windscreen whereas the A3 seems to stick to the stream of water system.
  21. cuke2u
    cuke2u Well-Known Member TFSI Owners Group Audi A4 S-line owners group saloon
    5,085
    1,387
    The viscosity might affect how they wash. This would vary according to how dilute the mix is...
