Headlamp washer jets not working .............?
vw754 Sep 24, 2013
  1. vw754
    vw754 vorsprung Durch Technik
    2,329
    58
    Hi,there,my headlamp washer jets aren't working,when i use windscreen wash,wiper work ok,screenwashers work ok,but no jets come out of the bumper to wash headlamps.
    I know the passenger side washer jet is missing,well part of it i think is,i did cambelt not long ago,when i took the bumper off i noticed one was missing then,you guys come across this?
  2. rabhrab
    rabhrab Member
    132
    24
    Check your Owners Manual as I think that you will find that your headlights need to be switched on before the washers work. I seem to remember that they don't operate every time you do a screenwash, only the first wash after your lights are switched on. Hope this helps?
  3. vw754
    2,329
    58
    jumped in car turned on ignition,then headlamps,used the washer still no go,cant find a separate fuse,???????
  4. hades-
    9,481
    646
    is the water pipe connected behind bumper ?
  5. vw754
    2,329
    58
    i dont know.......there was nothing off,not that i noticed anyway.....if it was diconnected,id get water on the floor....right?
  6. hades-
    9,481
    646
    well when you took the bumper off did you reconect the pipe ?
    as part of the jet is missing it may have been disconected and pluged at some point.
  7. A4B8Sline
    A4B8Sline Active Member
    211
    30
    Might sound silly but is your reservoir nearly empty. When mine gets low the head lamp wash stops working. However the normal windscreen wash will keep working for a few washes until I get the low warning light.
    The headlamp wash works on water pressure. As above lights need to be on and if the headlamps have been washed recently by the jets they won't pop again for a while.
  8. vw754
    2,329
    58
    ummmm its very nearly empty....il fill it in morning and let you know,thanks for that hope it works,then il buy a new jet and sort it.
  9. NHN
    29,328
    1,708
    Well tbh if a jets of, then no point even asking for help until that's been fixed, if the previous owner knew jet was missing, then they may have disabled headlight washing with vcds, so replace jet, turn on headlight & test spray, if nothing then check vcds coding.
  10. claudefrog
    claudefrog Member
    372
    the system will not hold pressure with only 1 jet. replace the broken washer and go from there.
    they can be replaced from removing the wheel and splash guard, I had to replace one recently and was able to do it this way.
  11. vw754
    2,329
    58
    thanks....easy job or easier if bumpers off?
  12. NHN
    29,328
    1,708
    If the systems down, then I would remove the bumper & fit new jet then make sure its all working fully before putting it back on, otherwise you could be pissing in the wind.
  13. vw754
    2,329
    58
    thanks
